1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How can an 01 f350 have a GVWR of only 9200 lbs?
Old 10-07-2015, 12:38 PM
tilopa's Avatar
tilopa
tilopa is offline
I'm looking at buying a 2001 F-350 7.3 diesel, and the sticker on the door (according to the owner as I have not seen it yet) says the GVWR is 9200.
I did a carfax on the vin and it does come up as a f350. In looking at Ford's specs on the f350's SRW they say the lowest GVWR they built was, I think, 9600.
Why would this truck only be 9200?
Old 10-07-2015, 01:49 PM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
a given truck... with almost nothing on it is GVWR... then the weight of options added to the truck.. even from the factory...... is deducted...
so a fully loaded truck will not carry as much as a stripped down truck with same drivetrain...
Old 10-07-2015, 01:59 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,193 Likes on 819 Posts
My 95 xlt obs cclb srw has the 9200 lbs gvwr yours being newer should have more
Old 10-07-2015, 02:26 PM
tilopa's Avatar
tilopa
tilopa is offline
The GVWR is how much weight the truck can haul, it does not matter what weight you add, from the factory or otherwise.
You take the GVWR then subtract the actual weight of the truck with whatever "options" and that is your payload capacity.
Old 10-07-2015, 03:09 PM
Chuck's First Ford
you are the expert..
I just fixed them for 40 plus years.
Old 10-09-2015, 05:23 AM
tilopa's Avatar
tilopa
tilopa is offline
Well you could have actually responded to what I said by pointing out how I was mistaken or what I was not understanding. How much you know about trucks is demonstrated by what you say or do not by showing us your resume.
It is unclear what you are saying, so the GVWR (the rating of how much the truck can haul based on factors like breaks, springs, shocks, tires, axle etc. can be lowered at the factory because of the weight of added "options"?
Again adding weight to the truck will change how much weight the truck can haul but how does that change the GVWR?
Old 10-09-2015, 05:52 AM
Chuck's First Ford
Deleted... go ask a Ford dealer.
Last edited by Chuck's First Ford; 10-09-2015 at 05:57 AM. Reason: Not being Paid.
Old 10-09-2015, 06:03 AM
T diesel's Avatar
T diesel
T diesel is offline
Here you go.....What does GVWR mean?
Old 10-09-2015, 11:04 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Lowest I see is 9900 of all body styles...
https://www.fleet.ford.com/truckbbas...1/fsersdcd.pdf
Josh
Old 10-09-2015, 01:35 PM
tilopa's Avatar
tilopa
tilopa is offline
Exactly what I said. I guess that was meant for Chuck's First Ford.
Old 10-09-2015, 01:39 PM
tilopa's Avatar
tilopa
tilopa is offline
Right, so how could the door sticker on this truck be only 9200? Maybe is was built for another country? But that would have shown in the carfax.
Old 10-09-2015, 02:21 PM
HuntsDucks70's Avatar
HuntsDucks70
HuntsDucks70 is offline
you are 100% correct, the only thing i would change is this: The GVWR is not how much the truck can haul, but how much it can weigh.
Old 10-09-2015, 04:14 PM
Bullitt390's Avatar
Bullitt390
Is it a really early build 99? Like January/February 1998? I had a brand new first week February 1998 F350 that was an oddball when it came to brakes etc that didn't match late build 99-04.
Josh
Old 10-09-2015, 04:28 PM
bobv60's Avatar
bobv60
bobv60 is offline
I would want to see it with my own eyes. There are a lot of numbers there, front axle, rear axle, gvw, all in pounds and metric.
mtl-diesel
2017+ Super Duty
05-18-2019 11:05 PM
vavtx
2017+ Super Duty
07-17-2017 11:07 AM
Sleepyguy
2017+ Super Duty
01-27-2017 11:39 PM
FinallyaFORD
02-15-2009 02:59 AM
mlc5967
03-03-2003 08:04 PM
Quick Reply: How can an 01 f350 have a GVWR of only 9200 lbs?
