Turn Signal problems
Old Oct 7, 2015 | 10:57 AM
Montync's Avatar
Montync
My turn signals will not work with the engine running. With the engine off they will. With the engine running if I move the ignition like I am going to turn it off they work.. any Ideas is it the ignition switch or ign cylinder
Old Oct 7, 2015 | 02:33 PM
Franklin2's Avatar
Franklin2
What year and model truck?
Old Oct 7, 2015 | 02:36 PM
Montync's Avatar
Montync
It is a 1984 ford f150 xlt 302
Old Oct 7, 2015 | 02:46 PM
Franklin2's Avatar
Franklin2
After you start it, wiggle the keyswitch to help seat it. This is a common problem with those trucks. If you put a new ignition switch on the column underneat the dash and wd40 the upper portion where the key goes in, it usually fixes it.
Old Oct 7, 2015 | 02:49 PM
Montync's Avatar
Montync
Thanks for your help. I will give it a shot.
Old Mar 29, 2016 | 09:43 PM
Montync's Avatar
Montync
New turn signal switch and ignition switch fixed my issues.
Bramage
Aug 28, 2015 05:37 PM
Shake-N-Bake
Sep 25, 2012 10:26 PM
Meter maid Rita
May 29, 2010 02:09 PM
mwilson
Electrical Systems/Wiring
Oct 27, 2002 11:00 PM
nissanjon
Nov 22, 1999 12:43 PM
