1982 F150 Build Up!
1982 F150 Build Up!
Ok so about a month ago I picked up a 1982 F150 2wd 4.9 4spd for $700. The truck has absolutely no rot on it and is incredibly clean. The PO told me it spent the last 20yrs sitting inside a mechanics shop. Aside from the body/chassis, mechanically the truck is in poor condition from sitting so long. I pulled the oil pan the other day and found a piece of a piston skirt laying on the bottom along with massive amounts of sludge. I plan on replacing the engine with a 302 or 351 I haven't decided which yet. Also hoping to find a 4spd with granny gear to replace my current transmission as it's the SROD 4spd w/overdrive. I'll post some more pictures soon of the truck/progress.
Here's the only picture I have of the interior at the moment. It's in pretty good shape, but I am missing a door skin and the dash has a few small cracks around the speaker. The seat is in perfect condition which is a plus, but it's an ugly red .
Tonight I worked on disconnecting some wiring and hoses from the engine to get it ready to be pulled. Just have to get the picker and unbolt the engine mounts and it'll be out! Hopefully I'll have time to pull it this weekend.
I am doing an 82 build as well. Gary Lewis may have a door skin you can get fairly reasonable. He also has a lot of parts for these bullnose trucks.
I will post a link to my thread. I am about to get started on the motor rebuild and swap.
I would swap in a 351W. Those are the truck small blocks. The 302 is more suitable for a car. They don't have the low end torque the 351's have.
Good luck F-ReV!
Good luck F-ReV!
Good luck F-ReV!
Good luck F-ReV!
That's awful I'm so glad my whole interior isn't red haha. The truck is pretty solid just needs a good amount of mechanical work from sitting so long, which I rather do mechanical work than body work any day!
Was able to pull the engine from the truck today. I definitely underestimated how big these inline sixes are, it was a bit of a pain in the *** to pull out of the bay. Put the engine on a stand and began pulling off as much as I could. I can't believe the amount of sludge build up that's in this thing!
Continued pulling the motor apart today, hoping I can keep up the fast pace and get this thing done!
The cylinder walls look to be in good shape. Ran my finger across the them and can't feel any marks. According to the ODO it had 100k on it, and I don't think it rolled over because it's been sitting the past 20yrs.
