Alberta Chapter Join Chapter, Leader: Puddy
Aerostar Heater Problems
Old Oct 6, 2015 | 05:17 PM
FordGrrl's Avatar
FordGrrl
I took my 1996 Aerostar to get a coolant leak fixed. It had leaked down 4 litres+. I noticed the gauge was in the red. ( thank goodness, I saw it ) When I got my vehicle back from the shop the rear heater worked but the front heater didn't. I took it back and they flushed it out to get any air bubbles and now the front heater works and the rear heater doesn't work. Could it be the controls that are faulty. If so, is that very expensive. I'd rather have front heat then rear heat for defrost etc.
Or could it be something else? It's odd that I get one or the other but not both.
Thanks, I'd appreciate any advice.
Old Oct 7, 2015 | 01:57 PM
seventyseven250's Avatar
seventyseven250
Hi FordGrrl. Not sure if you posted in the Alberta sub-forum on purpose, but you will probably get more responses in the Aerostar sub-forum.
Aerostar - Ford Truck Enthusiasts Forums
If you're from Alberta, welcome aboard, and if not, thanks for dropping in!
Old Oct 7, 2015 | 09:22 PM
FordGrrl's Avatar
FordGrrl
I think I've found the right place to post this now. Thanks for your reply.
( I'm an Albertan for sure )
Old Oct 8, 2015 | 09:22 AM
seventyseven250
No problem, and welcome aboard! This Alberta sub-forum is pretty quiet, so replies in here may take a while to arrive, but there is a good crew of us locals.
When you have a minute, take the time to put your location into your profile, and also the details of all the fords you own into your signature. The more details you have in those two spots, the easier it is for folks to help you out with specific answers.
rg500 mike
18
Jan 14, 2024 08:46 PM
FordGrrl
Oct 9, 2015 08:02 PM
Romes
17
Dec 20, 2014 10:11 AM
pedrorairez
Mar 4, 2010 08:34 PM
joe evans
Aug 16, 2004 08:04 PM
