1960s stright axle frames
Old Oct 5, 2015 | 08:32 PM
1961 f100 4x4's Avatar
1961 f100 4x4
are the frames the same on f100 to f250 4x4 for size for how tall they are and thickness
Old Oct 5, 2015 | 09:15 PM
1964FORDTUF's Avatar
1964FORDTUF
What do you mean "for size" and "how tall"? Length? Rail height? What are you looking to do?
Old Oct 6, 2015 | 06:21 AM
jowilker's Avatar
jowilker
Same year you should find very little noticeable differences. You should be able to work with it. You are not firing a rocket into outer space.
John
Old Oct 6, 2015 | 07:24 AM
1961 f100 4x4
I know mid 70 chevy pickup were the same between 1/2 and 3/4 was not shure about ford thanks
Old Oct 6, 2015 | 06:20 PM
1961 f100 4x4
I know I'm trying to find newer axle for my truck can't find none around here the only ones will fit is off from a 77.5 to 79 club cab or 78 or 79 f250 I found a set of f250 he wants 300.00 for the front one 100.00 for the back one I might go that way
Old Oct 6, 2015 | 06:59 PM
1964FORDTUF
Hi -
I assume you are doing a similar modification like I did on my 64. I have 77.5 F250 axles in my 64 F250 4X4. Sometimes you are much better off buying a complete truck, thats what I ended up dong. If you can find a 77, 78, 79 F250 4x4 with blown motor, or totaled out body, you will get everything you need in one shot to make the swaps.... Good luck and enjoy. Like your 61 by the way....
Old Oct 6, 2015 | 07:52 PM
1961 f100 4x4
I found a Dana 44 1/2 ton but they want 600.00 plus shipping is 175.00 I also need it for my weight of my engine and it has the right gears in it that helps a lot
Old Oct 7, 2015 | 10:23 AM
sseebart's Avatar
sseebart
Make sure the Dana 44 is in good shape before you commit--it cost me much more than that to have mine rebuilt.
~Steve
Justinvz
Dec 26, 2017 08:23 PM
DernMooseAk
Oct 24, 2005 12:16 AM
