2004 ford f150
Old Oct 5, 2015 | 07:26 PM
Luckett35's Avatar
Luckett35
2004 ford f150
I'm having a little trouble with a 2004 ford f150 5.4 originally it had the timing chain and phaser rattle but ran fine .tore it apart cam phaser on one side and guides on both cylinders was bad.put new timing chain and everything else and new phasers .put it back togather starts fine but has a hesitation from 500 to 1000 rpm.And a miss under a load going down road but it has no codes. what I'm wondering if it was a tooth out or out of time would it set off codes thanks
Old Oct 6, 2015 | 09:23 PM
LxMan1's Avatar
LxMan1
It may not throw a code if the chain was off a tooth.
How many miles have you put on it since the repair?
Old Oct 6, 2015 | 09:47 PM
Luckett35's Avatar
Luckett35
Probably around 30 to 50 and idled around 3 hours it seems to idle good if you push gas down about half way at idle it's has a slight hesitation between 500 to 1000 rpm and when driving if run easy it's seems fine if you run it hard or put on load it's like a miss at higher rpms thanks
Lk40hp
2004 - 2008 F150
Sep 13, 2024 07:28 AM
Eric11973
Modular V8 (4.6L, 5.4L)
32
Apr 16, 2017 12:35 PM
keltic25
2004 - 2008 F150
Dec 14, 2012 08:47 PM
