97' HD 460 start trouble
Old Oct 5, 2015 | 03:56 PM
KICKEDBACK's Avatar
KICKEDBACK
first start of the day..turns over fast and trys but won't catch. turn off key and try start #2 and it starts on first rotation and will continue all day. Next morning..same thing?? Wondering if it's a fuel problem, air in lines or leak or wha? Hope some one knows cause it's weird. Thanks
Old Oct 5, 2015 | 04:20 PM
timbersteel's Avatar
timbersteel
Sounds like weak fuel pump.
Either check it with a fuel pressure tester or you can try cycling the key on and then off 2-3 times and then try to start it. If its the fuel pump, its on borrowed time.
Check it correctly with fuel pressure tester and if its marginal, get a new pump before your left stranded sooner than later.
1997fordf350
May 18, 2013 10:54 AM
blee1ash
Aug 10, 2010 03:14 PM
Dodge/Cummins
Oct 28, 2008 01:48 AM
holdem
1997 - 2003 F150
Jan 2, 2007 12:42 PM
mgm5555
Mar 24, 2003 08:34 AM
