'97 460 starting problem
Old Oct 27, 2008 | 02:19 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I've had it for a year or two and this is my first problem.
I'm guessing fuel pump but....
If I turn the key on and off a few times it will start, if I spray starting fluid in the intake it will start, otherwise no-go.
Turn key to start, engine turns over fine-nothing. Turn key off and back on sputters a little-no start. Couple more cycles of this and eventually it fires-up.
I'm a diesel truck guy, do these trucks have a fuel pump IN each tank, I'm guessing so.
I think I switched tanks and got the same resuls but I can't gaurantee that.
Never had a fuel problem with my '90 351 either.
Don't think it's an air filter problem.
Old Oct 27, 2008 | 12:50 PM
andym's Avatar
andym
The only way to find out for sure if it's fuel pressure is to put a pressure gauge on it.
Yes, there is one pump in each tank.
Old Oct 27, 2008 | 12:59 PM
Lazy K's Avatar
Lazy K
I agree with you, sounds like low fuel pressure. And yes there is a pump in each tank. When you turn the key to "on" do you hear the pump run for a couple of seconds? How long since you changed the fuel filter? This probably sounds a stupid question but with you being a diesel guy, during starting or failed starting do you press the accelerator pedal? Have you tried to pull any stored error codes? Have you got a pressure gauge such that you could check the fuel pressure with key "on"?
If nothing else this will give your post a bump.
By Quaddriver,
There is a collar..........removable only by a hydrogen bomb.
Old Oct 27, 2008 | 02:18 PM
Dodge/Cummins
I have no idea why I didn't think FUEL FILTER duuuhhh!
I'll try that first.
It doesn't get driven that much so I'll try that and let you know.
THANKS!
I do always use the accelerator pedal on my IDIs (pre-Powerstroke) as it opens the fast idle solenoid but I didn't think it would make a difference on a fuel injected gasser.
I can hear the fuel pump run every time the key's turned off and back on.
Old Oct 27, 2008 | 03:11 PM
Lazy K's Avatar
Lazy K
THANKS!
On EFI, during cranking, the further you hold the accelerator open the less fuel will be injected. Handy if the engine floods!
Old Oct 28, 2008 | 01:48 AM
Dodge/Cummins
Didn't know that.
fordf1501991
19
May 30, 2019 06:32 PM
lovemy150's
Jun 7, 2014 05:59 AM
bigbasshb
May 3, 2010 08:29 AM
bmonnig
Jan 11, 2007 08:48 PM
darrengee
1997 - 2003 F150
Feb 4, 2006 06:19 PM
