AE questions
Old Oct 5, 2015 | 08:34 AM
HKusp's Avatar
HKusp
AE questions
It has been awhile since I have messed with AE. I was rudimentarily proficient with it and had used it when I was having issues with injector o-rings awhile back. I had data logged a few things and sent them to Rich and also to Jody at DP Tuner. I have in the past changed my tire size with it when I went up to 315/75/R16's. I recently went back down to 305/70/R16's so my speedometer is off about 1-2MPH at 60. This morning I hooked up AE to run a few diagnostics(I am having ABS issues) and to change the tire size back down to accommodate the smaller tires. I, for the life of me, could not find the setting to change the tire size. Where the heck is it?
Thanks, in advance, for helping out a technologically challenged brother.
Old Oct 5, 2015 | 11:47 AM
scottddove's Avatar
scottddove
You have to look under anti lock brake section. When you are prompted to select vehicle at the bottom of the window it will default to enhanced power train, you need to select anti lock brake instead. Then go to the section you would perform the on board tests you will find it there.
Hope this helps. Scott.
Old Oct 5, 2015 | 05:21 PM
HKusp's Avatar
HKusp
Thanks Scott. I will give it a try. I appreciate it.
brcman
Jan 31, 2011 02:53 PM
allen03
19
Mar 13, 2010 09:29 AM
Tim98TA
Computer Chips & Tuners
Dec 13, 2009 02:00 PM
O2BNMUDD
Apr 9, 2009 10:53 AM
STFXGEO
Nov 21, 2005 05:49 PM
