Radius arm bushings
Old Aug 4, 2003 | 09:36 AM
415dave's Avatar
415dave
Question Radius arm bushings
Hello, I drive a '93 F-150 fwd, this weekend I started to change out the radius arm bushings. Instead of tearing apart the front end to do it, I knocked the rivets out of the rear radius arm bracket, replaced the bushings, and bolted it back together. My question is, do I need to have the front end aligned now, or should it be alright? Haven't driven it yet, still need to bolt the passenger side together. Anybody have any idea? Thanks.
Old Aug 4, 2003 | 10:14 AM
larry derouin's Avatar
larry derouin
Radius arm bushings
By removing the mounts and re-installing them along with new bushings you've changed the effective length of the radius arm slightly.
It would be a good idea to go ahead and get an alignment done if the tires are new or fairly new. If tires are worn you can probably wait till you replace the tires.
HOWEVER! If you drive it and you get some shimmy, wobble or roughness in the front end, get an alignment NOW!
Make sure you install GRADE 8 BOLTS and nuts.
Hope this answers your question.
Larry
Old Aug 4, 2003 | 05:41 PM
rclarke's Avatar
rclarke
Radius arm bushings
GRADE 8 BOLTS FOR SURE but also self locking nuts and flat washers. NO LOCK WASHERS.
Old Aug 4, 2003 | 06:29 PM
415dave's Avatar
415dave
Radius arm bushings
Hey rclarke, what's wrong with lock washers? I did use grade 8 nuts and bolts, but also used lock washers. Easy enough to change out if I need to, just wondering what's wrong with them. Thanks for the replies.
Old Aug 4, 2003 | 09:46 PM
rclarke's Avatar
rclarke
Radius arm bushings
I have seen many lock washers open up, break and fall out. That leaves the bolt very loose. I worked in a Ford dealership for many years and did all suspension repairs during that time. The actual Ford recommended bolts and nuts were grade 8 with forged on washer head and locknuts with forged on washers. I don't know where you could get them since it took me a couple of years to get our parts department to find them.
Old Aug 4, 2003 | 10:23 PM
steve83's Avatar
steve83
Radius arm bushings
The more common name is "integral lockwasher". Most hardware stores stock them, but a fastener supply house will definitely have them.
