Miss only when engine is cold
Old Oct 2, 2015 | 09:49 AM
mechmagcn's Avatar
mechmagcn
As the title says, only when cold. When I start the truck cold it will "rhomp" 2-3 times and then level out. There is a dead miss until it gets up to operating temp. After that it runs fine, power is good and all is well.
This is my 97 F250 4X4. Oil is new, as is the fuel and air filters. The injectors I replaced with a used set and have only put a few hundred miles on them.
The truck is totally stock, no mods that I have found.
I'll try to hook up my AE this weekend to buzz and check contribution, but there is no CEL, so there shouldn't be any codes.
Probably one of the used injectors, but they ran well in the 97 F350 I took them out of.
Old Oct 2, 2015 | 10:02 AM
z31freakify's Avatar
z31freakify
Its either injectors or injector O rings. Another possibility is that you may still have air in the hpop.
Old Oct 2, 2015 | 10:04 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I wouldn't worry about it yet. Air in hp oil lines does funny things.
Old Oct 2, 2015 | 12:23 PM
mechmagcn's Avatar
mechmagcn
Shouldn't the air be purged by now? I have put close to 300 miles on it. Another thought, could it be air in the fuel? I did notice yesterday that the "fuel filter" sensor is seeping a little fuel. I have my extra fuel bowl resealed, ready to go on, going to do the IPR o-rings at the same time.
Old Oct 2, 2015 | 12:33 PM
MOOSE_MACHINE
It shouldn't be from the fuel. Most guys say up to 200 miles of heavy abuse to get the air out.
Old Oct 2, 2015 | 12:48 PM
lee00's Avatar
lee00
I wonder if you have 1 bad glow plug and it takes a couple of revolutions to get that cylinder to fire? any white smoke at start up?
Old Oct 2, 2015 | 02:46 PM
mechmagcn's Avatar
mechmagcn
All glow plugs are good. Its more like 3-4 miles to get that cylinder to fire. It does smoke when it starts, but clears up long before the miss goes away.
Old Oct 2, 2015 | 02:50 PM
mechmagcn's Avatar
mechmagcn
OK, I'll keep driving it and see if it clears up. If not its really not that big of a deal to put one of the old injectors back in there, I was smart enough to mark the known bad ones when I pulled them out. ;-)
Old Oct 2, 2015 | 08:54 PM
Action4478's Avatar
Action4478
More than likely its an injector poppet rather than an O ring . Pull the covers & watch the spill spouts at startup .
Old Oct 2, 2015 | 09:28 PM
mechmagcn's Avatar
mechmagcn
Thanks. Doubt I get that far this weekend, gotta get started on filling up the firewood racks for this winter.
A few more loads like this along with the cord on the porch ought to do it!
Old Oct 11, 2015 | 04:54 PM
mechmagcn's Avatar
mechmagcn
Finally had a minute to get back to the truck. Have driven it about 700 miles and it still misses when cold. Fuel economy is around where I expected at 16.5 MPG.
Hooked my AE up to it today. Injector buzz while cold didn't sound good with 3 barely audible. Contribution felt like it has two dead. Let it warm up and all injectors buzz as they should and contribution is even on all cylinders. It showed #s 1,2 and 7 as high to low side open, but after the injectors started firing is showed no codes at all.
Work has been hectic lately, hope I can find time to pull the valve covers this week. Really would like to pull my small camper to the lake on the 24th, but hate to have to warm up completely before pulling out.
Guess I should just break down and send the old set of injectors to Rosewood for a stock rebuild. Really hate to buy more injector o-rings to put some of the old ones back in.
Old Oct 11, 2015 | 07:59 PM
Action4478's Avatar
Action4478
Pull the covers & have a look . Make sure none of the solenoids are loose.
MONAVIERONJON
Aug 16, 2017 11:28 PM
250 STROKER
17
Aug 6, 2014 01:57 PM
97powerstrokeman
Apr 20, 2009 05:34 PM
smokineaglev
Dec 29, 2008 10:44 AM
CaseyJones
Feb 21, 2006 04:42 PM
