Cooling fan issue
Old Oct 4, 2015 | 11:29 AM
r2millers's Avatar
r2millers
To Bryan's point, mine too kicks in when ect's get to 219. Normally the "turbo prop" will only run for 10-15 seconds max before shutting back down and I see an immediate drop in ect's down to 210-215.
Speed doesn't seem to have any effect on its operation, simply temps.
Old Oct 4, 2015 | 12:22 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
At the lower temps, specifically with a/c on the fan will ramp up until 50 mph and then commanded off. The 217 temp spec is independent of vehicle speed.
Josh
Old Oct 5, 2015 | 03:46 AM
Thor'sHammer's Avatar
Thor'sHammer
Josh
It isn't on mine. If that temp hits 217, the fan ramps to full rpm. It's the same if I'm travelling 65 or 20.
Old Oct 5, 2015 | 06:21 AM
Bullitt390's Avatar
Bullitt390
You certainly misread what I wrote.
Josh
Old Oct 5, 2015 | 04:07 PM
Jmoen7's Avatar
Jmoen7
That's exactly what was written.
Old Oct 5, 2015 | 04:15 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
A/C on or off?
Old Oct 5, 2015 | 04:29 PM
Bullitt390's Avatar
Bullitt390
Originally Posted by BPofMD
A/C on or off?
With a/c on the engine fan is commanded to all sorts of weird behavior, but below 217 and above 50mph the fan is usually commanded to 0%.
On my XLT the fan behavior is completely different on Normal A/C versus Max A/C.
Josh
Old Oct 5, 2015 | 06:37 PM
FiveOJester's Avatar
FiveOJester
Josh
Agreed. Mine will go to 100% at idle with the AC going (FSS ~850rpm). As you drive off it quickly unlocks the clutch back to 0%. This takes a second and you hear a slight whine as the rpm's climb. Does this independent of ECT (typically it's 190-195 driving unloaded).
This really helps the AC work properly as it keeps the airflow up across the condenser. My 02 F150 didn't do this and the AC would stop working as well in stop-go traffic after a while. F250 stays nice and cool, even if it's 105F outside.
shredder
Dec 6, 2015 04:29 PM
f-350 turbo
May 21, 2013 01:10 PM
beemr
Oct 9, 2011 10:05 PM
eddiedebb
Jul 12, 2011 08:27 AM
vamstad
Escape & Escape Hybrid
Apr 19, 2011 04:31 PM
