1951 F3 marmon herrington
Old 04-26-2017, 10:07 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Not sure if the bull was a standard Studebaker thing or just the artists adding flair?
Originally Posted by truckdog62563
Factory spec is .020" oversize, 12.020". Same as 2wd.
How's the transfer case doing? Stu
Thanks for the spec.
The transfer case is all together and holding down the rolling cart, unfortunatly too many other things going on over the last year or so to get any more progress
. Last year had to rebuild the 5.9 cummins and reinstall in the 05 dodge 2500. And ive been working on a couple older commercial buildings on weekends and any other time i can manage to get them operational and leased.
The latest building shares a party wall with the old Studebaker bldg built in 189? I found the old artwork painted on the wall when up in the attic.
throw a back surgery in the mix 13 months ago and im starting to get a little done here and there on the F6 but not nearly enough.
No time to be bored. Haha
  #347
Old 04-26-2017, 10:21 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Oh yeah, I know you've had a heck of a year. Knew the F-2 wasn't on the front burner, but am glad to hear the case is back together. Stu
  #348
Old 04-26-2017, 11:16 PM
casper1999's Avatar
casper1999
casper1999 is offline
Transfer case looks great Josh!!! Is that a single speed?
  #349
Old 04-27-2017, 12:21 AM
jmadsen's Avatar
jmadsen
jmadsen is offline
Thanks.
No it is a 2 speed tcase. It is a fuller and goes in the 51 f2.
my 51 f3 marmon has the 2 speed wisconsin transer case.
Hopefully that one does not need to be rebuilt.
  #350
Old 09-13-2017, 03:08 PM
casper1999's Avatar
casper1999
I found some free time to spend on Brutus so started started down the rabbit hole that is my front end. So far so good, nuts and bolts are breaking loose easily and disassembly is progressing quite well....that is until I got to the pivot pins. Gonna have to fasion a puller to get those things out.
  #351
Old 09-13-2017, 04:05 PM
truckdog62563
We'll let you take us to school, and will be watching your creation of the puller. Chuck did my '52 so I'm no help, but intend to do the '51 myself. Stu
  #352
Old 09-15-2017, 06:13 PM
casper1999's Avatar
casper1999
I put together a tool ( described in the MH manuel as an alternative to the actual puller listed) for pulling the pivot pins on the steering knuckle. A 1/2 x3 inch fine thread (20) bolt, couple nuts and a large washer(2 inchish) with a 1/2 inch hole in it. Simple, even crude but very effective. Worked like a charm, both pins were out in 15 minutes and that's with taking time for pics. Forgot to mention the 3/4in pipe with 1 1/2 ID
  #353
Old 09-15-2017, 07:08 PM
casper1999's Avatar
casper1999
Found this in the grease, shear pin?
The bearing feels good but the race is not
Found some small pieces of something in the grease that I believe are from the edges of the bearing cups
  #354
Old 09-16-2017, 06:51 AM
truckdog62563
Do you see where the pin came from? You're doing us all a favor digging into this. If I didn't already have your build bookmarked, I would now. Stu
  #355
Old 09-16-2017, 06:41 PM
casper1999's Avatar
casper1999
No luck finding where the pin...s go!! That's right I found another one in the grease, they look to be two separate pins. They were escentuallly laying in the bottom of the steering knuckle but I don't see where they could've come from. On another note, my axle has undergone major surgery sometime in the past. Second pin on the left, same size and length as the other
Side 1
Side 2
Side 3
Side 4
  #356
Old 09-16-2017, 07:17 PM
truckdog62563
Not pretty, but got it back into service. Chuck's words come back to me. "The 3/4s weren't built that much heavier than half tons, but owners used them like they were F-5s". You might ask him about your pins, unless he comments here. Stu
  #357
Old 09-16-2017, 09:44 PM
casper1999's Avatar
casper1999
Yeah I suspect it got fixed right where it broke, some muddy ditch!!!! I also suspect that those pins went right where all those weld beads are, I have a few other questions for Chuck anyway so I'll be bending his ear soon
  #358
Old 09-16-2017, 09:55 PM
casper1999's Avatar
casper1999
Some more Carnage
  #359
Old 09-17-2017, 12:21 AM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
Did those pins snap off the upper and lower spindle caps? Very odd. And I have seen welding like that before. My f250 4x4 has a similar repair. My f250 also has similar damage inside the knuckle ball. I think your welds will survive in its new retired status. Unless its not retired.
  #360
Old 09-17-2017, 12:23 AM
truckdog62563
Ouch. Am I seeing right that the inner bearing chewed on the case? If so, machine work ahead, and metal fragments everywhere. Guess the fragments got into the bearing and chewed it up. Chuck had to replace my rear axle housing because it was hurt, but I don't recall him saying there were heroic measures needed on my front. I think you're pulling the axle. Stu
Quick Reply: 1951 F3 marmon herrington
