1951 F3 marmon herrington
#331
Just a couple of pics to share, I know how we all love pics so....
After a little reconditioning
Before
The drums cleaned up nicely, hardly removed any material the guy said.
I'm working on getting the drums and dust covers ready for a coat of paint Then it's on to the backing plates and steering knuckles followed by a list of parts and a phonecall to Chuck I think. 👻
Before
#332
I think you need to take them back to that brake shop to have them spend 15 seconds each with their drum gauge to tell you exactly what the inside diameters measure. Or find a more cooperative shop.
Edit - without that info there's no way to have your shoes relined. You won't know whether yours are close to spec, or way over spec and needing to do as Chuck described to have thicker linings shaped to the drums. Stu
#335
#336
#337
#339
What is the max the drums can be turned? im sure i read it somewhere on here on fte but dont recall.
thanks for posting part numbers on seals and bearings. Any anything else you use. Will be very helpful when myself or others get there.
I still need to compile my notes on my transfer case re-build.
#340
Great progress on your brakes.
How's the transfer case doing? Stu
#341
#342
I looked at my receipt for the work Chuck did on mine and see that he did replace the brake shoes rather than having them relined, but can't find the part numbers he lists so don't know if the M-H axle takes a special set of shoes. He will have to give advice on how much oversize is too far over for brake adjustments to remedy, and whether stock replacement shoes exist and will work. Stu
#343
#344
#345
