Sponsored by: Auxito
Need help!!!! 4.2 coolant
Old Sep 30, 2015 | 03:48 PM
Cory West's Avatar
Cory West
I've got a 97 with the 4.2 there is a puddle of antifreeze laying by the injectors. Can anyone tell me what gasket I need to fix it. Im thinking intake plenum but not sure
Old Sep 30, 2015 | 06:10 PM
steve(ill)'s Avatar
steve(ill)
check the heater hoses that run across the top of the manifold also. Best to get the motor hot, park and let it idle, then LOOK for the area that is leaking. Besides the manifold, you have a couple hoses, tubes and clamps attaching things.
Old Sep 30, 2015 | 06:35 PM
Cory West's Avatar
Cory West
I can't run it very long because it's missing so bad the light is blinking. It's also leaking in the same side I have the miss.
Old Sep 30, 2015 | 07:29 PM
steve(ill)'s Avatar
steve(ill)
yes, the coolant runs into the plug hole and shorts out the plug wire to ground.. Pull the wire off, blow out the coolant till dry and reinstall the plug wire. It might run better then. Look in that area for the leak.
Old Oct 1, 2015 | 09:33 PM
thzpcs's Avatar
thzpcs
UV dye might also be an option.
bronco6767
1997 - 2003 F150
Mar 14, 2015 05:38 PM
dragford
Jul 1, 2013 12:53 PM
ptaylor-01
Feb 20, 2012 11:24 AM
kennn
1997 - 2003 F150
Jan 26, 2008 02:54 PM
fireball69
1997 - 2003 F150
Feb 2, 2005 08:48 PM
