Air susp compressor runs more often?
Lately it seems my air suspension compressor has been running more than usual.
I havent yet sprayed soapy water around to check for leaks but i did turn off the susp switch for a couple days,and i didnt notice any ''sagging.
I also noticed that the check susp light comes on sometimes while parked on an incline.
Does this sound like a common problem?
1998 5.4 eddie bauer expedition
Hi. I have a similar problems with a 2000 navigator, instead the compressor kick in rises the rear and shut off and while driving it goes on at times. when park and the key is off you can hear the solenoids click then the rear drops down then when you start the truck up the pump kicks in and raises the rear. ???
That's what it's supposed to do. It kneels when off to allow for an easier time for people to get in, then it pumps up after you start driving.
Is that how Ford's air suspension is designed? That doesn't sound accurate to me at least coming from Cadillac air suspension setups. Typically the airbag is filled to a particular PSI or height that is monitored at which the compressor would shut off. The check valve built into the compressor acts as a fail safe in the case of a compressor failure will keep the compressed air in the airbags. The idea of the suspension constantly being allowed to loose air and then be filled back up to operating height just doesn't make sense to me and seems like it would just wear out the compressor at an accelerated rate as well as airbags constantly being decompressed and then inflated daily I would think can increase the rate the bags developing cracks/leaks opposed to the system reaching designated ride height and keeping it at that height consistently which is what Cadillac air ride systems are designed to do at least.
Doesn't the front drop also, and then raise back up with the rear?
The air suspension system is designed to improve ride, handling and general vehicle performance for static, on and off-road driving conditions.
The load leveling feature of the air suspension automatically keeps the vehicle at a constant level if a load is added or removed from the vehicle.
The height adjustment feature automatically controls the vehicle height over a range of approximately 5 cm (2 inches) based on vehicle speed, ignition position and selection of two or four-wheel drive modes.
The air suspension automatically puts the vehicle at its lowest height when ignition if OFF to provide easy entry and exit. When ever a door is opened (including the liftgate) the system memorizes and maintains the height of the vehicle until all doors are closed or until vehicle exceeds 16km/h (10mph).
The air suspension system raises the vehicle to its normal ride position when the ignition is turned on, all doors are closed and the transmission is shifted into gear.
In 4WD Low the air suspension system will not move to it’s lowest height. In 4WD Low, the air suspension system raises the vehicle above the normal ride height at speeds below 40 km/h (25 mph) to improve ground clearance. In 4WD Low, do not exceed 56 km/h (35 mph).
When the vehicle is in motion, the air suspension system will adjust the vehicle’s height according to ground clearance and speed to maximize ride comfort.
It is normal to occasionally hear a buzz or clicking from the vehicle’s air suspension system when the ignition is turned off. The system stays energized for 40 minutes after the ignition is turned off to compensate for any load changes made after the vehicle is parked.
The reason for the strut style conversions is because they offer a similar ride quality to the air ride setup. I converted my previous vehicles with rear air suspensions over after blowing $$$ to keep repairing the air ride issues. Cadillac's are notorious for air compressor failures, air bags prematurely leaking... etc so I finally gave up and converted the suspension on my 02 cadillac seville and 03 escalade over... no more sagging rear ends... no more money going into fixing the issues... when I sold them I explained that I converted them and the new owners won't have the headache I went through or the money to repair it over and over.
