A vacuum disaster
Old Sep 28, 2015 | 08:33 PM
Romancethestone's Avatar
Romancethestone
A vacuum disaster
I am so screwed. My truck (1985 f-150 351w 4x4) came out of the southwest, it's where I bought it 11 years ago. Defrost wasn't an issue, but it is now in the midwest.
I couldn't figure out why I could get vent air, not defrost and floor. The vacuum lines I have are black/blue strip to the main motor and the black/yellow strip and black/red strip to the motor for floor-defrost.
Somehow a HOT wire sliced through the black/yellow tube near the control box (it's totally melted and each end sealed like with a hot knife). The black/red strip tube is melted alittle bit (collapsed in on itself, but not cut in two).
The melt happened several inches from where the tubes leave the right side of the control box (the melt didn't happen up by the motor). On that side of the box is a 'battery' of rubber vacuum tubes. Can that all be pulled from the side of the box and replaced with a whole new set? Or does it take a whole new control box that comes with those tubes already attached?
For the moment, I thought about splicing the two ends with a really small diameter tube inserted inbetween, then sealing the seam. Any thoughts??? I haven't asked a question in forever because my problems are usually so simple, I can find the answer in a search. Sorry so long, but Thanks Guys. Eric
Old Sep 29, 2015 | 04:25 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Brittle hard vacuum lines are usually spliced by slipping a piece of small (3/32"?) rubber vacuum hose over both ends.
Can you trim off the sealed ends and do something like that?
What would have caused a wire to get glowing hot without blowing a fuse first?
Old Sep 29, 2015 | 07:17 AM
Franklin2's Avatar
Franklin2
That's what I do. Cut the ends clean and square, and then get some small vacuum line, the kind that you use for your windshield washer lines, and slip it over the plastic line. You can slip it way up on the plastic line and it won't come off.
Old Sep 29, 2015 | 08:50 AM
Romancethestone
ArdWrknTrk and Dave
Yes, I can do that Thank You, that makes a lot more sense than reducing the inside diameter of the hole further down. Trimming the ends flush would not be a problem to reestablish that pathway.
I called the previous owner last night (we worked together for the same company a long time ago). The only thing he could remember was his son installed a new radio back in the mid nineties and something went wrong a week after the install where the power wire got super smoking hot. The cut is below and to the right of where the radio mounts....makes sense.
(on a side note: he was amazed I still have this truck (same engine, trans, everything-I still drive it everyday-just put new tires on).
Old Sep 29, 2015 | 12:04 PM
Romancethestone
Not Pretty, but it works perfectly! Thanks again guys. I don't know why it didn't occur to me, I just stared at the melted hose thinking D'OH!
[/URL]
Old Sep 29, 2015 | 12:15 PM
1986F150six's Avatar
1986F150six
Don't you just love it when a plan comes together?
Old Sep 29, 2015 | 07:32 PM
maytag906's Avatar
maytag906
Nice job! Sometimes the hardest fixes are the easiest............
Juniorssrollin
1997 - 2003 F150
Aug 4, 2015 08:40 PM
daltonruff
1997 - 2003 F150
Apr 1, 2013 02:09 PM
navigatorstang
18
Feb 16, 2011 10:06 PM
murph1
1997 - 2003 F150
Nov 6, 2008 10:18 AM
broncr
Apr 9, 2003 03:25 PM
