Directional issues
Old Sep 28, 2015 | 03:02 PM
56fordguy's Avatar
56fordguy
Directional issues
Hi I have a 75 f100. I am getting closer to finishing my project. Well I have all new bulbs and flashers. I can't get my blinkers to blink. I can make them blink manually when I move the handle on the steering column . When I turn the headlights on I can't even get them to blink. I'm lost. Please give me some suggestions . Thanks Mike
Old Sep 28, 2015 | 04:34 PM
HoustonDave's Avatar
HoustonDave
first guess - bad flasher grounds. Second guess - did you maybe replace the bulbs with LEDs? When you switch to low-resistance LEDs there isn't enough resistance for a conventional flasher to make the bulbs flash, so you have to change to a flasher which cuts off and on electronically no matter what the resistance of the bulbs is.
Old Sep 28, 2015 | 04:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different flashers:
T/S flasher plugs into the back of the instrument cluster.
H/D 4 way flasher (has a louder CLICK) nestles into a bracket that's retained to the backside of the dash w/a screw.
Old Oct 2, 2015 | 06:49 AM
crazedfox's Avatar
crazedfox
Humm, 40 year old turn signal switch.
Try replacing it. After a looong term in service, they do tend to wear out.
Usually is just that simple...
Should problem persist after new turn-signal switch install, drop back in & we'll find & fix it.
Stevaroo01
Aug 29, 2014 09:54 PM
montana_highboy
Apr 6, 2009 04:31 PM
mechman_50
Aug 2, 2008 07:43 AM
dawiecoetzee
Oct 3, 2006 07:40 PM
C Holmes
Aerostar
Feb 13, 2004 06:14 AM
