anyone w/o mass air use a K&N AirCharger ?
well, same thing as a FIPK bassically, but for trucks that dont have mass air... it replaces the air box (open element), the two tubes connect to the cone rather than the one tube with mass air...
anyways, anyone use one?
anything (good or bad) anyone ccan tell me is muchly appreciated
thanks
thanks
well i decided to get one!
when i got my engine bored the mechanic told me it was dusted... either the paper filter in the airbox sucked or the K&N filter i replaced the paper filter with sucked or air got by the filter (i think air got by the filter)... so i wanted to eliminate the airbox entirely...
so i got this K&N AirCharger... noticed a bit of an improvement (big improvement from a paper filter, bit of an improvement from the K&N panel filter... rpm range is a bit higher and it sounds great when you step on it!
now i'm thinking of maybe (not right away) getting two intense performance bigmouth filters to replace this K&N cone filter (two tubes connect to the cone (speed density)...
i know it wont match mass air but i cant get mass air anytime soon as it will cost me roughly $1,500.00 CAD - which i need for a dana 60 front end.
i just wanted to see if anyone has any opinions or suggestions.
thanks
thanks
i have just installed a k+n fipk on my 93 ext cab 4x4 with the 302. god does it sound **** when you romp it. i dont have anytime tests yet but i am working on it. but there is a noticable differance in the performace and how fast people snap their necks to see what is coming down the road. btw i also installed march underdrive pulleys
An idea instead of buying two cone filters is to go to an exhaust shop and have them weld you a "Y" that fits into the two tubes and converts it to one larger tube. I would suggest getting the "Y" tube cut from whatever the intake hose size is to a singe 3.5" outlet. That way if you ever switch to Mass air the 3.5" filter will still work!!!
