evap code 446
Old Sep 28, 2015 | 11:15 AM
Mangelsen22's Avatar
Mangelsen22
evap code 446
I have a trouble code of 446 and can't find the wiring for the solenoid valve at the canister. I think I should have constant 12 volts and the computer is regulating the ground. but I don't see the constant 12 volts. I don't have a wiring diagram so don't know where it is supposed to come from.
Old Sep 29, 2015 | 11:45 PM
F150Torqued's Avatar
F150Torqued
@Mangelsen22
May not be any help to you - but I've placed the relevant pages from my 2004 F150 wiring diagram on my server temporarily. You should be able to download or print it out from here: www.devoll.com/Public/f150-wiring-Engine-Performance-wiring-pgs1-to-6-of-6.pdf Have no idea what differences there would be with an '08.
But It looks like, on page 1 of 6, that there is a Fuse (32) (15A) in the fuse box at tha "A" Pillar kick panel that provides the 12 volts to the Solenoid that you're looking for. Don't know if you can trust the wire color (Red/Yel) or not. Perhaps this will help.
Old Sep 30, 2015 | 02:21 PM
Mangelsen22
code 446
thanks I think this is what I need. again Thank You!
Old Sep 30, 2015 | 06:13 PM
Mangelsen22
446 evap code
Thank you very much. Found an open at the connector on the frame under the drivers door. Someone had probed the wire and it corroded off. I could cuss them but am just glad to have found the web site and help. Mangelsen22
Old Oct 2, 2015 | 01:04 AM
F150Torqued
Thank YOU for reporting back on the SUCCESS. It's provides the satisfaction that motivates everyone to try to help fellow FORD guys here!
spence340
Feb 21, 2019 03:58 AM
Dads 95
Sep 17, 2018 09:22 AM
jniolon
Apr 28, 2018 01:02 PM
njstevens
Dec 27, 2007 08:43 AM
