on/off/on - again P0153 code
Old Sep 27, 2015 | 08:11 PM
rosadoco's Avatar
rosadoco
Trailering
Hi, I've read through most of the forum and have found threads that touch on my problem, but none that address it.
I have a 1998 Mercury Mountaineer AWD 5.0L V8. I've been getting the P0153 code off and on for about 3 months.
I read on another forum that bad gas caps can cause the problem, well, I've replaced the gas cap with a new OEM one and that seemed to help stem the tide a bit.
As it often seems to pop back up when the tank is 1/4 or less, I fill the tank, and that helps some. But it still happens.
This Thursday, 2 days after I changed the spark plug wires, it began misfiring on the #6 cylinder and the P0153 code came back and stayed on.
I swapped the #5 & #6 plugs, cleaned up the area and reinstalled the wires with dielectric grease. No more misfire, but the code did not clear.
So, I also changed the O2 sensor that kept kicking off the code. I used the OEM, Bosch O2 sensor.
I started it and it ran beautifully. Next day, I was driving and that damn code came back. I stopped and had breakfast, it was gone.
Off and on all the rest of the day, disappearing even while I was driving
What gives?????
Old Sep 28, 2015 | 06:47 AM
shorod's Avatar
shorod
What year is your Explorer and which engine does it have (SOHC V6, OHV V6, or V8)?
-Rod
Old Sep 28, 2015 | 07:12 AM
rosadoco's Avatar
rosadoco
Trailering
My apologies...I have a 1998 Mercury Mountaineer AWD 5.0L V8.
geta4x4
Feb 28, 2009 06:56 AM
raldur
1983 - 2012 Ranger & B-Series
Mar 1, 2005 03:05 PM
Tom Norman
Mar 6, 2004 10:49 AM
K_SCOTT_L
Mar 8, 2002 10:43 PM
