generator to alternator conversion - Help?
Old Sep 26, 2015 | 04:59 PM
Lewis1960's Avatar
Lewis1960
Hello, I have a 1960 F100 6 cylinder 223ci.
The generator has finally burned out after lots of time trying to regulate it and lights dimming and battery running low.
I would like to change to a Powermaster PowerGen Alternator one wire system, or something similar. I've heard I shouldn't go with a one wire though. Is there any reason for this? I won't be putting in a stereo or anything. It is just to run the truck and keep the lights from draining the battery while driving at night.
Please give me your tips. Is this a simple installation? Do I need to buy any extra parts? Should I replace the battery cable?
Thanks for your help!
Old Sep 27, 2015 | 10:25 AM
Maltman's Avatar
Maltman
Here is what I used. Need new universal mounting arm, spacer and battery cable. Very simple and,i couldn't be happier with set up. Pics in my gallery, I was able to re-use belt from gen
Joe
Tuff Stuff One-Wire Alternators 7068 - Free Shipping on Orders Over $99 at Summit Racing
Old Sep 28, 2015 | 01:43 AM
Lewis1960's Avatar
Lewis1960
Thanks Joe,
I'll look into it. I may have to go with the more expensive one that looks like a generator. In Switzerland, everything is supposed to be "original" to pass inspection, so I think it has to look like a generator. Kind of silly, but it will be easier that way. Thanks for your help!
T
Joe
Old Sep 28, 2015 | 08:15 PM
economan's Avatar
economan
I'm on year 3 with my 1 wire setup in my 64 econoline no probs to report.
on my 58 M100 I am running the delco 3wire alternator.
Only thing however I will recommend is if you have an ammeter in your gauge cluster it will have to be changed up to a higher amperage unit as the one wire alts put out a lot more current.
Mikie
Near Ottawa Canada
58 m-100 panel & 64 econoline p/u
chromedom
Feb 26, 2015 11:09 AM
elkarcher1716
48
Apr 29, 2014 09:03 AM
artfuldodger
Dec 31, 2008 11:12 PM
rusbukt
Apr 25, 2008 09:28 PM
echo
Electrical Systems/Wiring
Oct 7, 2003 10:39 PM
