Tachometer Troubleshooting
Old Sep 25, 2015 | 10:53 PM
DrZoom's Avatar
DrZoom
I am having issues getting my tach to work. Right now, when I turn the engine on, the tach turns backwards and settles at 6500 rpm where it stays, regardless of engine speed. I have a duraspark 2 setup. There are a lot of splices, but I think it is wired correctly - not positive though. Below are some pictures
There is a positive wire coming from the starter relay that splits into two wires. One goes to the + terminal of the coil, the other goes into the red wire on the two-wire harness at the ICM
For the other harness, three wires are going to the distributor, and one is going to the negative terminal of the coil (which should be sending a signal to the tachometer). There are two extra wires coming out of the harness that are part of another harness, but aren't hooked up to anything. What are those for?
Here is the wiring diagram I've been working from. Is there something under the dash I should be checking out? Any help is greatly appreciated. I would really like a functional tachometer!
http://webpages.charter.net/1bad6t/D...rkWiringFW.gif
Old Sep 26, 2015 | 08:42 AM
subford's Avatar
subford
It looks to me like that someone has converted the ignition system from a Duraspark 3 system to a Duraspark 2 system.
Duraspark 3 system:
Old Sep 26, 2015 | 08:59 AM
DrZoom's Avatar
DrZoom
Thanks, good to know. What would be the best way to go from here to get my tach working? FYI, it's a 1990 EFI engine that was converted to carb.
Old Sep 26, 2015 | 10:05 AM
subford's Avatar
subford
I see now it is a 1987 so it would not have had the Duraspark 3 system.
Sorry I had just got up and was not reading the year and so on.
I do not know if you have a stock tach or a after market tach.
Did it have a 460 carb engine in it before?
If the tach is wired right and it is doing what it is doing then I would say replace the tach.
Old Sep 27, 2015 | 08:30 AM
DrZoom's Avatar
DrZoom
It's a long story....1987 truck (originally a 351w), currently has a 1990 460 that was converted to carb. The parts on the truck run from 1979 to 1993, so my fix will likely require some creativity.
The tach is factory. So far, I've only gotten the speedo and volt meter to work. It's a gauge by gauge project trying to get them all to work. I'm just trying to find out if something like a short would cause the needle to move but then stay put at a certain RPM. When I got the truck, the tach didn't do anything at all, so I suppose what I've got now is an improvement......
Cornettpd
Apr 16, 2019 10:57 PM
rowdyredneck
Aug 3, 2013 10:45 AM
Marc150
Electrical Systems/Wiring
Nov 13, 2004 09:11 PM
xpatout
3.8 & 4.2L V6
Sep 5, 2003 08:32 AM
topher
1978 - 1996 Big Bronco
Jun 25, 2000 12:58 AM
