vacuum problem?
Old Aug 3, 2003 | 09:58 PM
cwu192's Avatar
cwu192
vacuum problem?
I have a 77 Ford 4x4 with 400 engine. Has light knocking noise under light gas pedal load. Thought it was collector gasket on right side exhaust. Changed gasket same noise. Checked timing and when plugged up vacuum line with golf tee to check timing the ticking went away. Put it back on vacuum advance and it began ticking again. What gives? Don't really understand the vacuum scenario. Thank you for any advice. Dean
Old Aug 3, 2003 | 11:03 PM
johnsalterego's Avatar
johnsalterego
vacuum problem?
77's had an EGR setup as part of the emission controls - if it isn't working correctly you will have too much vacuum advance. Is all the original emissions stuff still in place on the motor?
Old Aug 4, 2003 | 10:01 PM
cwu192's Avatar
cwu192
vacuum problem?
I have edelbrock intake manifold with aftermarket distributor. Everything else is pretty much stock. Would too much vacuum advance cause that ticking sound under light gas pedal load? What would be the cure? Readjust the timing? Thanks for the reply.
Old Aug 5, 2003 | 12:18 AM
johnsalterego
vacuum problem?
Yes, that vacuum advance being to agressive would cause it; I'd check a few other things before blaming it:
Edlebrock makes both EGR and non-EGR manifolds... so that doesn't necessarily mean the EGR has been removed...
if you just readjust the timing you are going to loose power - since you have an aftermarket distributer you may want to check with the manufacturer on how to re-curve the vacuum advance section to be a little more conservative at part-throttle (if you no longer have the EGR setup...)
Old Aug 5, 2003 | 01:33 AM
Torque1st's Avatar
Torque1st
Posting Legend
vacuum problem?
This current topic is about the same problem:
https://www.ford-trucks.com/forums/s...hreadid=138472
Da_Lariat_Chariot
May 29, 2016 12:00 AM
Jagesage
20
Dec 25, 2015 11:35 AM
emgee
15
Feb 7, 2015 10:47 AM
mikearthur69
1997 - 2003 F150
Feb 27, 2013 08:40 PM
wanabe2
Mar 25, 2011 06:47 AM
