Sponsored by: Real Truck
2003 5.4 tick, tick, tick
Old Mar 24, 2011 | 11:43 AM
wanabe2's Avatar
wanabe2
I have a 2003 5.4 that is driving me nuts! It has this anoying tick coming from the passanger side wheel well. I just replaced all the exhast manifold studs and the gasket, but its still has this noise. What is causing it? Im thinking it valve related? I first thought a cam phaser, but its a 03 not a 04. Thanks
Old Mar 24, 2011 | 11:50 AM
BACKWOODS99's Avatar
BACKWOODS99
i have the same thing in my 99 5.4 i was told it was my lifters and the shop was deffinately right. if you turn your truck on, open the hood and listen real closely you'll hear them as the motor idles
Old Mar 24, 2011 | 01:52 PM
acf6's Avatar
acf6
i think i might have the same thing in my 03 but with 43k miles.. i have a video ill try to get uploaded shortly
Old Mar 24, 2011 | 07:40 PM
wanabe2's Avatar
wanabe2
So what do I do with it?
Old Mar 24, 2011 | 08:34 PM
waywardfool's Avatar
waywardfool
My '99 5.4 has had lifter noise for over 100k miles (217k now). Worst coasting downhill in the mountains. Went to 20w50, that helped.
I wouldn't worry about it, mine started about 110k. That's about 5 years, hasn't blown up yet.
Old Mar 24, 2011 | 08:38 PM
alwayschooseford's Avatar
alwayschooseford
This is pretty common, mine does it too, so did my brothers. I think it is almost always the exhaust manifold gasket. I just haven't replaced it because everyone says the rusty studs break off into the head. I did, however, put a louder exhaust on for the sole purpose to drown it out.
Old Mar 24, 2011 | 08:39 PM
alwayschooseford
Modular engines do not have lifters, yours is probably the manifold gasket also.
Old Mar 24, 2011 | 08:45 PM
mojo1's Avatar
mojo1
I had 2002 with 5.4 that had a tick, I finally found out what it was when it blew the sparkplug out striping the threads. I thought it was a manifold gasket leaking.
alwayschooseford
You should consider going to another shop, the sohc 5.4 is a modular engine, no lifters, no pushrods.
Old Mar 24, 2011 | 08:47 PM
alwayschooseford
It's funny my brothers '00 5.4 was the posterchild to common 5.4 problems and the manifold gasket problem and spark plug problem sound very similar until his spark plug blew out of the head which made it very obvious.
wanabe2's Avatar
wanabe2
Let me get this right-a 2003 5.4 does not have lifters? My exhaust studs/gasket on this side was just changed and is not leeking.
Old Mar 24, 2011 | 08:50 PM
dkf's Avatar
dkf
Broken exhaust manifold studs which cause an exhaust leak is common on the 99'-04' SDs with 2V modulars. It seems 1 out of 3 trucks in my area between those years with that engine have an exhaust leak you can easily hear. Some are really bad but the owners do not seem to care and just keep driving. On a carbureted engine an exhaust leak isn't a huge deal but its a different story on FI vehicles with O2s sensors.
Old Mar 24, 2011 | 09:10 PM
Zedrive's Avatar
Zedrive
There are hydraulic lash adjusters in the valve train.
Lifter/lash adjuster very similar no. They make it so you don't need to adjust the valve lash like solid lifter set ups.
Old Mar 24, 2011 | 10:02 PM
BACKWOODS99
thanks good to know. i wasnt very happy with them anyways. 99% of the time i do all the work and maintenence myself but i just couldnt figure out that tick sound
Old Mar 25, 2011 | 06:47 AM
waywardfool
thanks, I have learned something, too.
Darn, that's the second time in my life I've ever been wrong.
coolidge54
Mar 8, 2019 12:03 PM
housba2007
Modular V8 (4.6L, 5.4L)
Feb 10, 2017 06:59 PM
walkerfamily7
Jan 20, 2017 11:21 PM
TooHuge
2004 - 2008 F150
Feb 1, 2016 01:32 AM
Gloz
1997 - 2003 F150
Dec 13, 2015 06:45 PM
