7.3 Electric Fuel Pump
Old Sep 25, 2015 | 04:53 PM
jmuenchow's Avatar
jmuenchow
would a electric fuel pump from a 6.5 Chevy diesel work? 8psi shut off psi with 35 gph
Old Sep 26, 2015 | 11:26 AM
jmuenchow's Avatar
jmuenchow
Bump Please
Old Sep 26, 2015 | 12:14 PM
jdemaris's Avatar
jdemaris
I don't know what "bump" means in this context. But yes -it will work if mounted as close to the tank as possible. GM 6.2s and early 6.5s have the same model injection pumps as the Ford 6.9s and IDI 7.3s (DB2 Stanadyne/Roosamaster). The DB2 can be run with no fuel pump at all since it has its own but that makes filter bleeding very difficult. Doesn't require any pressure. Just don't want to give it too much (over 8 PSI) or it might make the timing advance when you don't want it to. Timing advance works off of fuel pressure.
genscripter
13
Sep 29, 2015 07:42 PM
homer4111
33
Mar 11, 2015 09:21 PM
Tom Callan
Mar 4, 2014 12:00 PM
jcruth
Mar 6, 2007 12:42 AM
buckskinfordgirl
Jan 8, 2007 06:57 PM
