Caliper And pads
Old Sep 25, 2015 | 07:21 AM
Iaff113's Avatar
Iaff113
Caliper And pads
My left front caliper has begun to stick so I am going to replace that and the pads. Anyone have anywhere they received good prices? Looks like around 210 for a left caliper and pads from white bear lake. And rock auto re mans are around 181 including pads
Old Sep 25, 2015 | 08:23 AM
TooManyToys.'s Avatar
TooManyToys.
If you checked the freedom of movement of the pistons and found an issue, fine, but brake hangup can also br the pads hanging up in the bracket, frozen slide pins, or brake hose if you didn't already know this.
Motorcraft caliper's from either source will be the same and Ford is the only company that requires the caliper rebuilders to check the rebuilt caliper's for proper piston force movement, so they are the best.
THE BLUE HEAP
34
Sep 9, 2018 02:46 PM
Andrew Jarmain
2009 - 2014 F150
Jun 1, 2018 06:50 AM
Thoth88
1983 - 2012 Ranger & B-Series
Feb 6, 2009 11:25 PM
Proud Veteran 87
May 8, 2008 07:00 PM
Shedstomper
1997 - 2003 F150
Aug 7, 2003 09:09 AM
