New member serial number question
Old Sep 23, 2015 | 08:06 PM
skiersey's Avatar
skiersey
Just bought a 47 1/2 ton from my uncle he bought it 30 + years ago and never got to it. Has no motor or radiator other wise mostly there.
Got the serial number off the frame near steering gearbox.
*b99c 770097*
Firewall and glove box tags are there but not readable currently.
Any info on the serial number and ideas to clean the tags would be greatly appreciated
Need ideas on how to open the doors. Handles are sticking.
Old Sep 24, 2015 | 11:00 AM
tacomacream's Avatar
tacomacream
Hello, I may have some answers for you. Are you locked out of the pickup? I see that you have seen inside the glove box. This tells me that the window is down. Or, are the door handles just not working smoothly?
The 770097 number is the sequence number that year as far as I know, and the c stands for commercial. The 1/2 ton pickups were called commercial cars back then.
Then the next year they called them Light Duty Trucks. So maybe that is not where the C came from.
Old Sep 24, 2015 | 11:07 AM
Lumbah's Avatar
Lumbah
Are you sure that is b99c and not 699c on that serial number? I looked it up on this site:
Tech Tip - Ford V-8 Serial Numbers
Look up info for *b99c 770097*
WWII PRODUCTION
...1946...99A650280......99A-1412707
...1947...99A-1412708...799A-2002282
...1948...799A-2002283..899A-2374315
NOTE: It has come to our attention that there may have been serial numbers beginning with 699 for 1946 vehicles, instead of 99 as listed above.
ALSO, For 1942-1947 Pickups, a letter after the first numbers indicate the size truck: C = 1/2 ton, Y = 1 ton, T = 1 1/2 ton
Old Oct 1, 2015 | 09:14 AM
skiersey's Avatar
skiersey
I was wondering about 6 vs b. But it is a b stamped in it. I will assume that is human error and mental to be a 6.
Old Oct 1, 2015 | 08:46 PM
38 coupe's Avatar
38 coupe
If you compare the first digit to the second and third digits, they look the same but upside down. The "b" or "6" looks just like a rotated 9.
Old Oct 9, 2015 | 11:24 AM
52 Merc's Avatar
52 Merc
It's a 6, not a b. Lower case letters were not used in serial number stampings, and many of the numbers were specifically stylized like that to prevent fraud from common stamps available.
49fordv8f4
1947 and Older Ford Trucks
Sep 7, 2017 02:43 PM
Bill in Bama
Nov 19, 2015 06:13 PM
gdp1701
Jul 28, 2015 02:10 PM
kmcisaac85
Mar 8, 2012 07:02 PM
Person25
Dec 12, 2010 04:22 PM
