How to wire a 6.9 engine
Old Sep 22, 2015 | 09:31 PM
Chubs80's Avatar
Chubs80
Trailering
I'm a little stuck here guys. So I put a 1964 Ford cab on a 1992 ford pickup frame. The 1992 Ford pickup i used had a 6.9 in it. I put an ATS turbo i had laying around on it and 7.3 injectors on it already. Where I'm stuck at is how to wire it to where it will run. I have the 64 cab and front clip mounted on the frame along with a flatbed I repaired and made fit. I'm only 19 and did all the work myself, i just need some more simple directions to wiring it. Thanks
Old Sep 22, 2015 | 09:35 PM
Chubs80's Avatar
Chubs80
Trailering
Here is an older picture when i first put the cab on.
Old Sep 22, 2015 | 09:41 PM
Chubs80's Avatar
Chubs80
Trailering
Here is when i first put the front clip. I used the old 92 ford radiator support and also swapped the front axle to a solid 1 ton axle. I will get a more current picture tomorrow.
Old Sep 23, 2015 | 07:09 AM
tjc transport's Avatar
tjc transport
i ain't rite
<p>welcome to FTE.</p><p>in reality, all you need is 12 volts to the fuel shutoff switch on the injector pump to get the engine to run.</p><p>having working glow plugs and gauges will make life easier though.</p>
Old Sep 23, 2015 | 09:11 PM
Chubs80's Avatar
Chubs80
Trailering
I'm going to have guages i just wanted to get it running so i could test light wires to figure out the rest of the wiring like guages, lights, etc. So do i just take the wire that's running to the fuel tank and put power to it and jump the solenoid to make the engine crank over?
Old Sep 23, 2015 | 10:46 PM
RacinNdrummin's Avatar
RacinNdrummin
IF you want a GP controller (Key on wait to start stuff) Find a 7.3 Controller and wire some Beru/Motorcraft ZD9 Glow plugs into the mix. Its a very easy setup to wire, and there are several diagrams on Google images if you do a search. If you want to keep it simple, Just wire the GP's up to a starter solenoid attached to a button inside the cab, and hold it for 10 seconds when the truck is cold.
Old Sep 24, 2015 | 02:06 PM
tjc transport
i ain't rite
to fire the engine, put 12 volts to the power connector on the front of the injector pump. you will hear it click, this will tell you the fuel solenoid is engaged to let it run.
Old Sep 24, 2015 | 09:12 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
^^^^^ What everyone else said, There is only one wire required to make these motors run, and it is basically an electric fuel shut off valve. it is the flat pin on the top of injection pump that is closest to the front of the truck. The entire rest of the motor is mechanical. Later we can tell you how to deal with glow plugs and gauges, but if you just want to hear her rattle, that is all you need. Of course you will need to power the starter unless you live on top of a very large hill and have a manual trans! Use ether sparingly to get her to fire. Just a little goes a long way, and too much will cause slow cranking and possible engine damage. I think it is awesome that at 19 you took on a project like this! The good news is, you started with possibly the most simple truck/engine platform you can get! Let us know how things go.
Good luck,
Mac.
Old Sep 24, 2015 | 09:18 PM
akamacgyver
Clueless spectator!
P.S. if you get it to fire on ether, but it won't stay running, you likely have air intrusion issues, don't keep trying ether, let us know what she is doing, (how long it runs, how much smoke, what color, any visible fuel leaks that sort of thing) We will straighten you out.
Old Sep 25, 2015 | 04:42 PM
Chubs80's Avatar
Chubs80
Trailering
Thank you, I will try doing this tomorrow if I have time.
Old Sep 25, 2015 | 04:56 PM
kla94's Avatar
kla94
Going to be a beauty!
Old Sep 25, 2015 | 05:01 PM
Chubs80's Avatar
Chubs80
Trailering
Good luck,
Mac.
I dont think it will need much ether or any at all to get it running because the engine was running a year ago in the original pickup. I will try giving power to the injection pump tomorrow. So do i connect the starter wire to the solenoid after that and it will crank over? Thanks for the reply, i'm excited to hear it finally run and will keep you updated.
Old Sep 25, 2015 | 05:23 PM
kla94's Avatar
kla94
No, you will need just a 12 volt power source, preferably one that you can switch on and off or unhook it safely, to the injector pump. You will have to wire your starter also if it's not already wired.
Old Sep 25, 2015 | 05:25 PM
kla94's Avatar
kla94
Sorry, just realized that you were actually talking about the starter solenoid.
Old Sep 25, 2015 | 10:00 PM
Chubs80's Avatar
Chubs80
Trailering
Well thanks, i will get more current pictures to show all the body work i did.
