zf5 question
Old Sep 21, 2015 | 09:53 PM
otpracer's Avatar
otpracer
zf5 question
I finally got my tranny out to do the clutch. I need some help identifying a part and it's purpose. There is some sort of phenolic piece with gear notches on it that goes over the input bearing retainer. Looks like the throw out bearing may rest against it. Mine is partially melted. Can anyone give me some clarity on this? Thanks.
Old Sep 21, 2015 | 10:37 PM
twigsV10's Avatar
twigsV10
I'm not a lot of help on exactly what that part is but... That's partially because if I'm going to the work of pulling the transmission to replace the clutch and throw out bearing you might as well replace the slave cylinder and throw out bearing as a unit. If the other parts are bad the slave isn't likely to be far behind and not a lot of fun to pull apart again to replace just that.
Old Sep 21, 2015 | 11:10 PM
thechief66's Avatar
thechief66
Most ZF's (maybe all, my memory is a bit fuzzy) have an external slave cylinder.
Old Sep 22, 2015 | 12:09 AM
twigsV10's Avatar
twigsV10
After looking on Rockauto.com I do believe you're correct, should've looked for the part he's looking for when I was there... I've had the privilege of owning non-ZF's....
Old Sep 22, 2015 | 04:32 AM
EPNCSU2006's Avatar
EPNCSU2006
What year and engine are you working on? Big block and diesel ZF transmissions use an external slave while the small block version uses a concentric slave. The concentric slave has a plastic piece that goes between a spring and the throwout bearing.
Old Sep 22, 2015 | 02:42 PM
Willz74's Avatar
Willz74
If that's what you're talking about I personally suggest replacing it if not it should be fine
scsnls
1997 - 2003 F150
Jul 2, 2012 09:04 AM
76250_4x4
Dec 29, 2010 03:41 PM
cnvrtd diesel junky
1983 - 2012 Ranger & B-Series
Jun 27, 2009 09:18 PM
jurgak
Jun 29, 2007 11:16 PM
DrFord
Sep 30, 2003 07:21 AM
