question about the throwout bearing
the truck is a 1990 f 150, 4.9 m5od. anyways i replaced the clutch and slave cly in july of this year and just recently i had to replace the throwout bearing because it started making noise. after replacing it i looked through the inspection hole and it looks like the bearing is constantly touching the clutch fingers and i dont think this is correct. the system is bled and the pedal feels the same as my last f 150 so im not sure if its ok or not. thanks
Think about it, you just said you have a spring pushing it out....
How would it NOT be touching the pressure plate fingers all the time???
what brand of bearing are you using?
Inline66
15
05-27-2016 01:41 PM
f250d4x4
05-30-2012 07:11 PM
frankebc
02-20-2001 09:42 AM
