1978 - 1996 Big Bronco
Starting Trouble
Old Aug 3, 2003 | 06:29 PM
Trucky18's Avatar
Trucky18
Starting Trouble
My 95' Bronco has a issuse with starting. When it is warm out side sometimes when i go to start it, i turn the key and nothing happens, the fuel pump relay kicks in and every thing else works like normal, but if i smack the steering wheel or fuse panel a couple times, it will start with no trouble. I only ask because recently it has been worse, and it has taken my 5 min of beating the crap out of the wheel to get it to start. The only thing i could think of was the ignition switch under tha dash, but i dont want to go just replacing random parts. any ideas? thanks
Old Aug 3, 2003 | 07:23 PM
steve83's Avatar
steve83
Starting Trouble
I'd say replacing parts is better than beating on the steering column.
Put a test light on the R/LB wire on the starter relay and see if it gets 12V every time you turn the key to START. If it does, replace the starter relay. If it doesn't, replace the ignition switch. You can see where it is in the GP Pics album in my signature link.
Old Aug 3, 2003 | 07:33 PM
chuck641's Avatar
chuck641
Starting Trouble
it could be the neutral safety switch, if its an automatic the shifter may not be fully in park or the switch on the column could be out of adjustment. try moving the shift lever around a little bit as you turn the key, my bronco has that problem. your beating on the steering wheel may be moving the shifter which will engage the switch and make it start.
Old Aug 4, 2003 | 12:05 AM
Trucky18's Avatar
Trucky18
Starting Trouble
I dont think its the shifter on the column, because some times i just hit the fuse panel lightly and it will work, i just resort to more extreme measures when i get mad. Thanks Steve i will check the relay
Old Aug 4, 2003 | 12:09 AM
Red_EB_Bronco's Avatar
Red_EB_Bronco
Starting Trouble
your column shifter could be the problem... its happened to me and I laughed when I figured it out...
Mbizzal
25
Jun 16, 2016 06:51 AM
Firedawg8812
Jun 8, 2015 02:30 PM
Mr. Crab
Mar 13, 2015 09:56 AM
jfish045
Apr 23, 2012 09:22 PM
Sundevil Brett
1983 - 2012 Ranger & B-Series
Nov 29, 2003 09:38 PM
