I need your guys help please. I have a 1965 352/sb/3spd .
Have had the engine out at the machine shop for a few months
now is the time to put it together. Have put most of it together.
I am not sure about the positions of the left and right front engine
supports that bolt on the block. My old gray matter ain't like it
used to be. If you guys can send a picture or something would
help me a lot
I have figured out the left and right sides,
I have not figured out which way the stud goes more to the front of
the engine or toward the rear of the engine because it will bolt up
either way?
I have figured out the left and right sides. I have not figured out which way the stud goes more to the front of the engine or toward the rear of the engine because it will bolt up either way?
Lower pic. 352 same as 360/390. Right & left specific engine supports (6028 aka towers/stands/perches) bolt to the frame rails.
Right & left specific rubber insulators (6038) bolt to the block, then to the engine supports.
