transmission
Old Sep 20, 2015 | 08:58 PM
ultraranger's Avatar
ultraranger
Originally Posted by RichS2659
UR, wouldn't a late model E4OD be stronger than a 4R70W? A C-6 derived trans versus a C-4 derived trans? A 4R100 vs a 4R70W?
The 4R70W is derived from the Ravigneaux plantary design from the FMX transmissions, although it isn't an FMX or C-4 - based transmission. It is a direct descendant of the AODE which is a direct descendant of the AOD although, the 4R70W is a much better transmission than the privious two versions.
I don't have any experience with an E4OD/4R100 but, it may be possible to install one or the other. I do know that the Baumann transmission shift controller I have for my 4R70W will also control the shifting of an E4OD.
Old Sep 20, 2015 | 09:24 PM
351Cleveland C4's Avatar
351Cleveland C4
transmission
E4OD/4R100 trannys are HUGE. I can't imagine how one would fit in a bump truck without a body lift.
I run the AOD and it fills up the tunnel pretty well...
Vickadelphia
Feb 7, 2014 07:32 AM
windsorfordever
Sep 2, 2010 01:20 AM
crestfallinman
May 11, 2010 08:25 AM
78f-150Supercab
18
Dec 8, 2006 05:22 PM
low springs
34
Apr 13, 2005 03:43 PM
