Tailpipe?
Old Sep 18, 2015 | 02:24 PM
HoustonDave's Avatar
HoustonDave
Tailpipe?
1978 LB 300cid with C6.... have EFI manifolds, Walker Y-pipe sourced - already got good advice for a muffler but the tailpipe is surprisingly difficult to source. Would like if possible to buy a 2.5" pipe for it... can probably live with 2.25". The old pipe is a whopping 1 7/8" and that seems to be all anyone lists when I check the usual catalog suspects, unless I go to a much later model truck - at which point I am not sure whether a pipe for say a '95 will fit right on a '78. Anyone happen to know a number for a larger pipe that will bolt on OK? (Tried posting a similar request on th Exhaust forum with no response months ago)
Old Sep 18, 2015 | 02:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Any muffler shop can bend you a new tailpipe.
Old Sep 18, 2015 | 03:15 PM
HoustonDave
I know, I was hoping for a bolt-on solution I could do myself.
Old Sep 18, 2015 | 04:43 PM
Jklnhyd's Avatar
Jklnhyd
why 2.5" for a 300? I have a 400ci and am using 2.25"
Old Sep 18, 2015 | 05:01 PM
HoustonDave
like I can said, I can live with 2.25, but I figure with the Walker Ypipe running 2.5", why not just hold that all the way out.
Old Sep 18, 2015 | 05:50 PM
HIO Silver's Avatar
HIO Silver
Give the RPM and HP level for a 300, a dual 2.25 system is good to go. Any bigger and there would be a loss of scavenging.
Another option is 2.25-inch muffler inlets and a single, 2.5-inch outlet.
Old Sep 18, 2015 | 06:28 PM
Roger Carter's Avatar
Roger Carter
Can't speak for our dents and later rigs, but ...
I had a '97 F-350 ('92-'96 body) and a muffler back exhaust system from an '87 F-350 slipped right in place, up and over the axle and out behind the rear wheel. Factory hangers and all.
Good luck.
Old Sep 19, 2015 | 12:16 AM
ShaneNP123's Avatar
ShaneNP123
I have EFI manifolds on my 300. Custom built y-pipe into 2.5 single.
I pulled a muffler and tailpipe from a 2010 F150 at the junkyard, paid $50 for it, the muffler fits great, its all 2.5" and mandrel bent. Also has a nice shiny tip
Old Sep 19, 2015 | 12:20 AM
ShaneNP123's Avatar
ShaneNP123
Old Sep 19, 2015 | 10:48 AM
HoustonDave
Shane -0 what yearis your truck?
HIO - think we're somewhat on the same page, I want to stick with a single exhaust and like the idea of 2.25-2.5" for improved flow - at the 300's hp any more is probably silly and possibly countereffective. I am just hoping to find something off the shelf, even if from another year, so I could do the work myself (and should be cheaper than having a shop make one.).
Rusty_S
Mar 16, 2021 10:07 PM
Rusty_S
Aug 11, 2019 09:19 AM
dpayne7571
Mar 30, 2019 07:47 AM
KAS300
Exhaust Systems
Apr 10, 2004 11:56 PM
warrior777
Exhaust Systems
Jan 21, 2004 09:51 PM
