Hooked up to one of our trailers and didn't have any lights or brakes. Appears after I shift into gear I get the trailer connected message? But not while idling and in park when I first plug in. After that if in park everything works. When I was backing up I got the trailer disconnected and trailer connected messages. I noticed marker lights fluttering. I got a trailer wiring fault at one point. I had a local place check the truck and all checked out. Problem with trailer? One of our goosenecks gets a trailer wiring fault once in a while on our 14'. Where should I start looking? Anyone else have any issues with factory integrated brake system. Thanks.
Hello I have a 2014 f250 sd i hooked up a trailer all lights were working. message on truck said disconnected and i had no brakes working on trailer... Any suggestions where to start... anything helps
