Sponsored by: Real Truck
Taking the yaks camping, a solution...
Old Sep 15, 2015 | 03:51 PM
Thenewboss's Avatar
Thenewboss
All Yakima. I've always had Yakima racks and never had a problem, we'll see how these hold up. A little rough getting the boats up there but that's what the gym is for...right?
PS...Etrailer is the best as usual.
Old Sep 15, 2015 | 04:51 PM
Ginther's Avatar
Ginther
You're not worried about the straps rubbing a spot on your grill?
I've always tried to avoid anything rubbing painted surfaces at highway speeds. The vibrations and movements of the straps will rub a bad spot quick.
Old Sep 15, 2015 | 05:04 PM
fishbones182's Avatar
fishbones182
Small piece of pool noodle would fix that
Old Sep 15, 2015 | 05:08 PM
Ginther's Avatar
Ginther
True.... IF ...... the pool noddle doesn't move too. Any dust that gets in between will act like sandpaper and make a blemish quick.
Unfortunately I learned the hard way years ago. Have been fearful of it since.
But I have been accused of being overly cautious sometimes lol
Old Sep 15, 2015 | 05:13 PM
ligito's Avatar
ligito
How about a rack that would mount them above the bed?
Old Sep 15, 2015 | 05:39 PM
Thenewboss's Avatar
Thenewboss
I have a tonneau cover that clamps to the bed rails and 99% of racks clamp around the bed rails, believe me I looked and I would rather have the cover. As for the straps rubbing the paint... not worried about it. There's a thick, soft rubber sleeve that goes around it where it contacts the vehicle, not to mention I'm not really concerned about a little bit of scuffing, to me it's a truck, not a show car...
Old Sep 15, 2015 | 05:53 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I used to buy Yakima, but their fit on my Focus is awful, just absolutely plain awful. Scratched up the door jambs, AND the who rack can shift backwards over time. Sucks because they worked great on my '02 Ranger and '07 F250, and the round bars make fitting other things like lights easier. I have two bike carriers and a faring on the car now, I won't put anything with more surface area than that for fear the rack will fail.
The buy-in cost for Thule is pretty steep, but I'm done buying q-clips from Yakima, next car I'll just pay up for the whole new system. Thule towers are better than Yakima for how they pull on the clips in the door frames.
Old Sep 15, 2015 | 06:04 PM
jsm180's Avatar
jsm180
I tried the Yakima roof racks on on my truck and only lasted about 5 miles. The way they clamp above the doors create too much wind noise for me.
Old Sep 15, 2015 | 11:46 PM
Thor'sHammer's Avatar
Thor'sHammer
This is what I've done for the forward mounts.
For the rear I used 1" heater hose, with a slot cut through both sides. I then ran a strap through it and close in under my hard bed cover. Works great!
Old Sep 16, 2015 | 06:45 AM
Thenewboss's Avatar
Thenewboss
Originally Posted by Thor'sHammer
This is what I've done for the forward mounts. For the rear I used 1" heater hose, with a slot cut through both sides. I then ran a strap through it and close in under my hard bed cover. Works great!
Good hack! I'll look into doing the front like that.
Old Sep 16, 2015 | 09:56 AM
scraprat's Avatar
scraprat
Top Answer: 5
I had an image of this from the title.
Old Sep 16, 2015 | 03:24 PM
Diamnd1's Avatar
Diamnd1
Me Too!!!
Old Sep 16, 2015 | 03:43 PM
Thenewboss's Avatar
Thenewboss
HA! This is more along the lines of, "The yaks taking YOU camping".
Old Sep 16, 2015 | 03:50 PM
Thenewboss's Avatar
Thenewboss
The driving I have done so far has not shown any appreciable noise increase, then again acceptable noise is subjective. Personally I expect a good amount of noise while driving a 9200 LB brick down the road...
Old Sep 16, 2015 | 03:53 PM
Thenewboss's Avatar
Thenewboss
They are all expensive to me. I have a Yakima bike rack and ski/snowboard rack in the garage left over from my Subaru, it would have been foolish of me to change systems at this point. I've had both and I haven't noticed any real differences that make one better than the other yet.
