Bolt problems
Old Sep 14, 2015 | 04:44 PM
Nathan Cox's Avatar
Nathan Cox
Bolt problems
Alright working on 88 Ford F250 460. I'm pulled timing cover off and found a bolt that had been snapped off at the block and have been trying to get it out drilled down center then took a bigger bit nd tried to center but it's off a little. And might hit threads. What would be easiest and best way. I have to they the timing cover and water pump flush of course any ideas?
Old Sep 14, 2015 | 04:48 PM
Nathan Cox's Avatar
Nathan Cox
Old Sep 14, 2015 | 04:49 PM
88XLTLariat's Avatar
88XLTLariat
You need to get the hole centered again. I don't know if you have limited access or not but you could try a smaller drill bit or router bit and try to re-center hole. It will be easier to remove with bolt extractor if hole is centered. Can you post any pics?
Old Sep 14, 2015 | 05:59 PM
Nathan Cox's Avatar
Nathan Cox
I posted one
Old Sep 14, 2015 | 07:07 PM
mrollings53's Avatar
mrollings53
Weld something to the bolt and twist it out. As far as repairing the hole; I'm thinking keensert, or fill with weld and re-drill and tap. To center the hole put the timing cover back on. Insert a steel sleeve into the hole that slip fits the timing cover, and use whatever drill bit fits the sleeve. Remove the timing cover, and drill to finish dimensions. Finally thread the hole with whatever tap you need.
Old Sep 14, 2015 | 07:10 PM
88XLTLariat
You might be able to "grab" it with an extractor. If you damge any threads, you can always use a tap & die kit to chase the threads.
Old Sep 14, 2015 | 08:02 PM
Diesel_Brad's Avatar
Diesel_Brad
You can drill out out then go to the next size larger bolt
Old Sep 15, 2015 | 01:08 AM
Toplait's Avatar
Toplait
Heat the area up with a torch...... Use an extractor...Well that's what I did on a few exhaust manifold bolts....may work for you to
projectdagger
Jul 16, 2013 04:44 PM
soco
Jan 3, 2013 03:19 PM
jaagen
16
Oct 23, 2012 06:53 PM
bubbahyde
Feb 6, 2006 01:21 PM
BROKEN88F150
Aug 17, 2005 10:01 AM
