F1 Mystery Part
No such thing as a '51 or '52 mystery part . Those are factory splash guards . Once you put them where they go you will see the corresponding attaching holes .These are some what hard to find . Back in the day they were removed for easy under chassis work & never put back since lifts were rare on the farm , ranch . mill & etc.The other case is they hung so low every large hole , tree stump & etc. caught them & bent them beyond repair . Have 2 sets on upay now .The top pair which is on the stock truck is a '52 set .The other 2 sets are '51's .The left side on each set is the same as the '52 right side has more curvature .
Thanks again. Your picture makes sense now that I know its orientation. I replaced the front cab corners and cab mounts on my truck so there are no tell-tale bolt holes. The mystery parts are the last two pieces that need to go back on my front clip. It has been apart for almost a year.
Jim
Deerbrook, WI
Jim
Deerbrook, WI
Jim
Deerbrook, WI
Jim
Deerbrook, WI
Thanks Wayne. I know now just where they go. This part of my truck was in BAD shape:
I purchased lower cowl replacement panels and had to sort of improvise the sheet metal for the front cab corner. What I did may not match-up perfectly with the contour of the mystery piece. I wasn't too particular about the sheet metal because it would be hidden by the fender. The black stuff is caulking covering some rather crude welds:
My truck spent its first six winters in Sault Ste. Marie, Michigan and the next 56 years parked outside in Wisconsin; it is rusty as a result.
Jim
Deerbrook, WI
Jim
Deerbrook, WI
EAK69
05-23-2013 12:55 AM
going slow
01-11-2009 11:51 AM
reamer
23
05-22-2007 11:12 AM
