Mirror questions
Old Sep 11, 2015 | 10:41 PM
Jaime74656's Avatar
Jaime74656
Mirror questions
I need some help with the towing style mirrors, I have a e99 7.3 with the curved style mirrors I am considering switching to the square style, are there ANY advantages the square style provide over the curved oval style?
Old Sep 12, 2015 | 04:47 AM
Supercab's Avatar
Supercab
If you have the "Flag-style" or "paddle" style mirrors you will really benefit from the '99-'07 style tow mirrors!!
If you already have the '99 tow mirrors you will LOVE the '08 & up tow mirrors!!
I recently swapped to the '08 up style for MY L99......
Old Sep 12, 2015 | 07:43 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The advantage is a nice big convex mirror which is very nice when towing or a camper in the bed. Heat and turn signals if you use the later model year mirrors. I love my 08 mirrors.
Old Sep 12, 2015 | 08:46 AM
cj45lc's Avatar
cj45lc
The 08 mirrors are quite a bit better when towing, with that said I believe they don't look quite as good as the originals but I'm keeping my 08's
Old Sep 12, 2015 | 08:54 AM
Jaime74656's Avatar
Jaime74656
I have the 99 style tow mirrors, I'm looking at pros and cons of of both styles (tow mirrors)
Old Sep 12, 2015 | 09:35 AM
William Mark Brown's Avatar
William Mark Brown
I current have these and they are terrible when towing my fifth wheel. They are on my list of upgrades.
Old Sep 13, 2015 | 09:40 AM
brian42's Avatar
brian42
Veteran: Navy
These are all in reference to the tow mirrors:
The '08+ style have better visibility (especially the lower convex mirror) but for me they don't match the styling of the 99-03 truck (plus they are the most expensive).
The late '03-'07 style ones have heat, turn signal, and marker lights and are the middle-priced ones.
The '99-early '03 style ones look like the '03-'07 ones but don't have any of the neat stuff listed above and are the least expensive of the three.
I had the OEM tow mirrors on my '03 and finally ditched those (after some good brush-beating off-road) in favor of the '03-'07 with all the "goodies" on them. I haven't wired up the extra stuff yet since the truck isn't set up for it and I've got to do it myself. The mirrors are the same as far as reflective surface (the casing is a little wider to accommodate the light cover) and I've gotten my custom lower dash from Riffraff (that has my switch for heat), timer relay, and the OEM style pins to put in the connector once I splice the lines for turn and marker lights. This way when I kill another mirror on the trails I can just plug in a new one instead of more cutting and splicing.
Old Sep 14, 2015 | 11:30 AM
William Mark Brown
Hey Brian42 do You have part #s to go with these? I want to upgrade my mirrors as well. I'd like them to telescope and possibly wire up heat and marker lights as well. Mine is a late 1999.
Old Sep 15, 2015 | 12:06 PM
brian42's Avatar
brian42
Veteran: Navy
Here is what I bought:
Ford Mirror Pair - 1AMRP00124 at 1A Auto.com
I don't remember what year they swapped over from the round plug to the square (actually rectangle) plug. If you don't want to cut the connector off and solder/splice the wires you can use this:
http://www.1aauto.com/ford-mirror-wi...=934700&y=1999
Looks OEM but definitely not OEM quality (but for less than 1/2 the price I can live with that). They don't vibrate any more than my OEM ones did. I did have one damaged in shipment. Customer service was very helpful and they shipped another one the same day that I called.
I've had them on for 6 months now and have been very happy with them.
Regardless you will have to wire up the heat, turn, and marker lights yourself since our trucks don't have that. I still haven't done that yet. I finally have all the parts (which is the easy part) but haven't found the time to start the project.
If you are interested I am using these pins (thank you to F250RockStar and ligito):
http://www.clipsandfasteners.com/For...0_p/a20475.htm
I bought this crimper since I figured if I'm going to do all this I might as well do it right:
Eclipse Tools 300-005 Pro's Kit AWG 20-10 Ratcheted Crimper, Non-Insulated, Open Barrel Terminals: Automotive Electrical System Tools: Amazon.com: Industrial & Scientific Eclipse Tools 300-005 Pro's Kit AWG 20-10 Ratcheted Crimper, Non-Insulated, Open Barrel Terminals: Automotive Electrical System Tools: Amazon.com: Industrial & Scientific
Here's a couple of the most recent threads I was referencing for this job:
https://www.ford-trucks.com/forums/1...-all-done.html
https://www.ford-trucks.com/forums/1...terminals.html
There's plenty more on FTE and "other" sites about this upgrade if you want to search here or Google it.
Good luck!
Old Sep 15, 2015 | 01:22 PM
Thomas White's Avatar
Thomas White
You can find these fairly inexpensively. Although I know nothing of their Quality. 99 07 Ford F250 Super Duty Excursion Towing Power Heated Mirrors Set Pair Signal | eBay
If you don't currently have the "Heat Option" you can purchase this: Ford Part#F3TZ18C621B
Here is how it's wired:
Old Sep 15, 2015 | 02:10 PM
jgilrfr's Avatar
jgilrfr
thanks for the wiring diagram and info
Old Sep 16, 2015 | 10:40 AM
William Mark Brown
Is the wiring diagram basically the function of the switch? Meaning is the ten minute timer built into it? Is there more to it than this? Mine is a 1999 XLT with power mirros but not power fold or heat so I would have to run additional wires to get the heat,fold,telescope,and turn signal/marker lights to work?
Old Sep 16, 2015 | 10:54 AM
scotttahoe's Avatar
scotttahoe
Her is how I did mine on a 99 truck. The plugs are different and will need to be changed. Although I used 07 style mirrors but should be the same for the 08 unless your doing the auto telescoping. Then you will need additional wiring info.
https://www.ford-trucks.com/forums/1...l#post14029532
This link has the pictures in it.
https://www.ford-trucks.com/forums/1...l#post13613546
Old Sep 16, 2015 | 09:05 PM
Firefighter 1406's Avatar
Firefighter 1406
I have had every mirror possible. I bought the truck with paddles, lasted about 2 weeks. Bought aftermarket 99 tow mirrors w/ heat. These where great. Got a great deal on some OEM 04 white king ranch mirrors w/heat and turn from a fellow fter. Loved these, liked the matching paint and the turnsignals. Not sure why the turn signals so much but really think it's cool. They are the best IMHO on these mirrors. I put a set of OEM 2012 take offs tow mirrors with heat, signals, and such on my dads truck, drove it once and had to have a set. They are so nice for towing. Plus top and bottom mirrors are heated on these. I personally after having both aftermarket and OEM feel it's worth the money for OEM, again that's my opinion. You can pick them up on eBay or craigslist pretty reasonably. Got mine from a wholesale place near me for $275. I have the switch above in the garage waiting to be installed. Now that I have the wiring diagram I will get them itch again to get that working before winter.
Old Sep 17, 2015 | 08:21 PM
Anthony Giovino's Avatar
Anthony Giovino
I too looked into doing this and have added it to the list, check this forum post if you want power fold and extend.
08-10 Tow mirror install - Ford Powerstroke Diesel Forum
