Need some Excursion wisdom...
Old Sep 11, 2015 | 10:22 AM
74Mav's Avatar
74Mav
Got home from work last night, passengers side rear wheel was smoking, and damn hot to the touch. Drivers side rear was hot, but not as bad as passenger's side.
My first thought was worst case sceneries - wheel bearings. After getting it in the air, in neutral, I can turn the wheels, but, it takes a lot of effort. There's no grinding noises, but, it sounds like a brake is in constant contact. I'm in the process of taking both wheels off, but, I'm leaning towards either the brakes/calipers or the ebrake dragging. It definitely smells like hot brakes, and not diff fluid.
Any other ideas?
Thanks,
Brian
Old Sep 11, 2015 | 11:12 AM
74Mav's Avatar
74Mav
My thoughts are, with 144k on the odometer, if I have to tear it down to service/replace the ebrakes, I might as well do the wheel bearings too....
Old Sep 11, 2015 | 12:19 PM
holeshotwalt's Avatar
holeshotwalt
These things are famous for sticky brake pins- the ones the pads slide on. They get crudded up and you have seen the result.
Remove, clean well, lube up with high temp lube (can't think of the name)
and you'll be good for a while. Do all corners, and depending on the stuff you drive over, determines how soon it needs to be done again.
Old Sep 11, 2015 | 12:21 PM
holeshotwalt
Permatex ceramic extreme brake parts lube
Old Sep 11, 2015 | 01:03 PM
Magnus E's Avatar
Magnus E
^This! Sounds like the common sticky caliper slide pins
Old Sep 11, 2015 | 01:25 PM
holeshotwalt
Crap! Thanks Magnus, that's what I meant!
My brain knew what I was trying to say, it just got lost in the translation to my fingers...
Old Sep 11, 2015 | 02:09 PM
74Mav's Avatar
74Mav
Well, after removing the axles so the hubs would spin freely, the passengers side definitely has a grinding crunching sound that I couldn't hear before. Wheel bearing.
Old Sep 11, 2015 | 02:22 PM
holeshotwalt
Well, good that you found it after work and not on a trip 500 miles from home...
Old Sep 11, 2015 | 03:11 PM
74Mav's Avatar
74Mav
How in the blue blazes do these rear rotors come off?!
I'd swear to everything holy they are one piece...
Old Sep 11, 2015 | 03:27 PM
Restlesswildman's Avatar
Restlesswildman
Remove caliper, then caliper bracket, make sure parking brake isn't set, then adjust the emergency/parking brake shoes down(usually rust and a lip exist in there), beat with your favorite hammer and wiggle the rotor off!
BTW I would bet you also had calipers sticking!
Old Sep 11, 2015 | 03:35 PM
05MilMachine's Avatar
05MilMachine
I had to use a slide hammer with an angle end on it. It destroyed the rotor but I was replacing it anyway. It was a royal pain to get off and my truck is a rust free Texas born truck. I wouldn't totally blame the wheel bearings until you get the brake rotor off and spin it. The ebrakes can make terrible grinding sounds.
Old Sep 11, 2015 | 04:20 PM
74Mav's Avatar
74Mav
Progress so far...
Old Sep 11, 2015 | 04:35 PM
74Mav's Avatar
74Mav
You might well be right. I'll be installing new hardware when it goes back together, so hopefully, that problem will be solved also.
Old Sep 13, 2015 | 07:27 AM
74Mav's Avatar
74Mav
Obviously I finally got the rotors off. A little PB Blaster works wonders. The seal on the PS hub looked dry and rusty, while the one on the DS looked ok.
The PS ebrake hardware was rusty and in pretty rough shape. The DS was wet, and smelled like diff fluid, worth all kinds of crap stuck to the inside of the rotor.
Since I had to replace the seals, I went ahead and replaced the bearings and races - which I don't think were bad now, but, with 144k on its odometer, I didn't want to put those bearings back in.
Replaced the PS brake caliper since I damaged it while taking it off. Replaced the DS caliper since it had a stuck piston. New pads as well. Should be finished this morning, as long as the rain is really gone. Lost 5 hours to rain yesterday.
Old Sep 15, 2015 | 09:47 AM
74Mav's Avatar
74Mav
Happy to say I put 250 miles on it since Sunday and wheel temps are nice and cool so far. Don't like it when the Ex sends up smoke signals....
