A/C question
Old Sep 10, 2015 | 07:43 PM
bigsquare65's Avatar
bigsquare65
A/C question
I have an 04 EX that needs the a/c charged. Can anyone tell me what oil type is used? The sticker with the information under the hood of mine is gone.
Thanks,
Pat
Old Sep 11, 2015 | 09:40 AM
az_r2d1's Avatar
az_r2d1
Unless you replaced any parts in the ac system it doesn't need any oil. If you did replace any parts it uses regular oil used in AC systems (PAG?)
If you are referring to the type of refrigerant, it is 134a
Old Sep 11, 2015 | 09:48 AM
projectSHO89's Avatar
projectSHO89
If refrigerant leaks, oil usually also goes with it. Unfortunately, you cannot know how much of the PAG oil has leaked.
Ford designation is YN-12b, commonly sold as ISO 46 PAG oil in your parts store.
Last edited by projectSHO89; Sep 11, 2015 at 10:04 AM. Reason: Correct part number and viscosity
Old Sep 12, 2015 | 09:20 AM
bigsquare65
Thanks for the info. I bought the ex and there have been repairs/upgrades to the motor. The a/c system is empty and I wanted to make sure I had everything on hand to recharge it. Thanks again.
Old Sep 12, 2015 | 09:31 AM
az_r2d1's Avatar
az_r2d1
Might want to pull a vacuum first and see if it holds. Still not a guarantee for no leaks. It will also remove any moisture from the system.
garyd
1997 - 2003 F150
Jul 3, 2017 05:57 PM
F-250 WARHORSE
Jul 8, 2011 08:42 AM
Coachfootball
1997 - 2003 F150
Jul 19, 2005 01:58 PM
levilevi2
Aug 12, 2002 09:58 PM
