Name that sound!
Old Sep 10, 2015 | 10:43 AM
Tarheel Blue's Avatar
Tarheel Blue
Name that sound!
A couple of weeks ago I made the jump and converted to DSII, rebuilt an old Carter YFA, new booster w/ an '87 MC and thought . . . "Hell, I'm in this deep, why not go to 3G also!"
Much to my surprise, everything worked out pretty well and thanks to all that have asked questions in the past, and especially everyone that has provided expert guidance, I've been able to correct some of my mistakes and avoid making LOTS of others. THANK YOU!
After the 3G switch, I would occasionally get some squeezing that I figured was the belt and the fact that I'm only able to put 1 pulley on it. It would only squeal for a short time and generally only at low RPMs.
Until recently . . . .
I've been trying to get everything in fixed up for the goal of getting it inspected this Saturday ( first time in 2 years), but yesterday the squealing got ALOT worse ( but went away after an hour or so of idling and driving around the block). Now this morning, it's really starting to scare me and I've started to worry that maybe what I think is simply a belt, but something much more problematic.
Please watch this video and let me know what your "professional ears" have to say.
Old Sep 10, 2015 | 12:37 PM
1986F150six's Avatar
1986F150six
Definitely sounds like the drive belt squealing. Perhaps you could provide a look at the front of the engine while it is running?
Old Sep 10, 2015 | 01:02 PM
Tarheel Blue
Was reluctant to start it up again until I'd gotten some feedback as to what the awful noise might be, but glad you asked for another vid to see the belts. As you'll notice, the noise completely goes away after a bit. Must be a belt? Not necessarily? And what's that hum I hear after the squealing goes away. Never heard that sound before!
Old Sep 10, 2015 | 01:32 PM
Brnfree's Avatar
Brnfree
If it was me I'd take all the belts off and turn each accessory by hand to see how it feels.
If I had to make a wild guess I'd say it's the smog pump.
Old Sep 10, 2015 | 01:34 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Is that a smog pump on there, left side? That could be your culpret. Do they have their own belt?
With the engine running, hold a bar of soap to the V side of the belt. Watch your fingers and don't try when you've been drinking. The soap will coat the belt.
Old Sep 10, 2015 | 01:41 PM
Tarheel Blue
Yup, Smog pump on top of alternator. I tried spraying water on belts yesterday w/ no change at all. Will try the soap idea.
Old Sep 10, 2015 | 01:52 PM
ctubutis's Avatar
ctubutis
Couldn't that horrific noise also be a bearing in one of the accessories?
Old Sep 10, 2015 | 01:53 PM
TeachNlive4ever
Go with a lube in the smog pump. Do you need it for the inspection?
Old Sep 10, 2015 | 02:00 PM
Ken Blythen's Avatar
Ken Blythen
x2....almost certainly a failing bearing (although, I haven't heard a smog pump begin to seize)
Old Sep 10, 2015 | 02:08 PM
1986F150six
The smog pump is powered by a small short v-belt which is driven by the alternator [2 groove pulley on the alternator].
If you suspect the smog pump, loosen and remove the belt to the air pump and then run the engine. I would not think the smog pump since after a while [video], the squealing stops. If the noise is caused by a bad bearing, most likely it will continue.
On this 2nd video, you do not show starting the engine. On the 1st video, the engine was quite difficult to start and the starter motor was used a good bit. This drains the battery and once started, the alternator works hard to recharge the battery. That puts a heavy load on the v-belt, which can cause slippage if everything [tension, alignment] is not correct.
Brnfree suggested removing the belts. Do that and start the engine. Do not run for long because the water pump will not be working. If there is no noise, then replace one belt at a time and you will soon determine what is making the noise.
TeachNlive4ever
Check if you have any idler pullies and give those a squirt of "shut the hell up" of your choice.
Old Sep 10, 2015 | 02:50 PM
Tarheel Blue
Hey Y'all,
Sorry, had to go get more beer
I tried the soap, no change.
Removed the belt from the Smog Pump and all seems well (for now).
Spent some time trying to get it to idle below 1K and see if I could lean it out a bunch as it's running VERY rich. MY EYES ARE BURNING!!!
Systematically turned the idle mixture screw and reset idle speed on linkage, back and forth, back and forth until the mixture screw bottomed out and still could not get it to idle below 1K. It was also running pretty rough at the time, but kept running. Decided that the running rich problem will have to wait and set the mixture screw back to where it smoothed everything out and brought the idle linkage screw completely out (not touching the carb at all) She's out there right now purring like a sewing machine.
By the way, I've spun the smog pump by have and it turns freely with no noise. Sure wish I could run two belts to the 3G, but the other pulley on the Alt would either have to go to the smog pump or the power steering pump. I need both!
Technically don't have to have a sniffer test here, but they are required to pass the eye test.
Yes, the started is yet another issue, but would like to address that after inspection. Plan to change over to a PMGR and have retarded the timing as much as I can to try and make it start easier, but still have those 3-4 HARD lugs before it gets into a more free spinning.
Gotta go back out anf check on the old girl to see if she's still idling!
Old Sep 10, 2015 | 03:18 PM
Tarheel Blue
So, she was doing just fine, still idling real smooth. Took a ride around the 'hood and have some slight bogging around 2K, but can live with that (for now).
Plan on going back out in a bit to see if she'll start (typically won't when hot) and if not, is my only option to do the PGMR conversion? Need to make this as reliable as possible, she's my DD. Need to be able to drive 10-15 miles to get to the parts/ beer store and be able to start her up when ready to come home (not 4 hours later).
What other things can I look into regarding the hot start problem?
Old Sep 10, 2015 | 03:21 PM
TeachNlive4ever
Timing, alt,battery, starter.
Old Sep 10, 2015 | 03:22 PM
TeachNlive4ever
What is a PGMR?
