I have a 2010 F-150 which has a problem that the dealer cannot figure out. When I leave the heater/air on when I shut the truck off upon restart the heater/air is off. The heater/air will turn on if I restart the truck within a few minutes but if it is left for say 15mins it seems the truck forgets where the heater switch was upon shut down. This causes a huge problem for my remote starter as the selection I need does not come on after leaving the vehicle for a time.
The codes for the truck are OK according to the dealer.
I have a 2010 F-150 which has a problem that the dealer cannot figure out. When I leave the heater/air on when I shut the truck off upon restart the heater/air is off. The heater/air will turn on if I restart the truck within a few minutes but if it is left for say 15mins it seems the truck forgets where the heater switch was upon shut down...
Welcome to the forum, unclejed1949. You may want to consider getting a second opinion about your climate control at a different Ford Dealership. Find some alternatives by entering your ZIP code here: Ford Dealers | Locate a Ford Dealer Near You | Ford.com How many miles are on your truck?
Thanks Crystal but I would think that all Ford dealers use the same computers to trouble shoot problems. I can try another not too far from home.
UJ
Hi UJ,
Let me know if you decide to go ahead and have another dealer check things out. Could you provide a rough estimate of how many miles are on your truck?
