1948 Ford Truck Heater/Defrost Control ?
Yes, you have a recirc unit.
The fresh air heater used a duct that ran from the passenger side kickpanel, through the fenderwell, to the intake just above the PS headlight. The heater unit was mounted very near the kickpanel. For the 48-50 versions, the fan/motor were in the fender well - and tended to die a horrible, rusty death.
Exactly correct. From a restoration standpoint, you are definitely better off with the recirculating unit. All self contained within the cozy confines of the cab.
The flip side, is that the fresh-air units worked pretty well, except that they had a pretty anemic blower motor that blew air at about the rate of an end-stage emphysema sufferer. For one thing, they were thermostatically controlled, meaning that the water valve on the firewall had a capillary tube that automatically adjusted the flow of hot water according to the setting of the temperature control ****. Pretty nifty.
Another was the ability to pull in fresh air. This aided greatly in dissipating the fog and frost on the inside of the windshield better. Allowing the dry winter air into the cab, then heating it, cut down on the moisture in the ambient air. With the recirc., all that moist air was contained, unless you left a window open/cracked.
Of course you could cut down on the amount of water vapor by just ceasing to breathe.
Croaking by corrosion!
hotairballoonpilot
10-07-2018 08:12 AM
HILLBILLY BOB
02-04-2015 09:57 AM
fordbigtruck
1947 and Older Ford Trucks
01-24-2002 08:24 PM
