Hotter spark plugs?
Old Feb 21, 2002 | 02:14 AM
groundrat's Avatar
groundrat
Post Hotter spark plugs?
I recently installed an MSD 6A ingnition in my 94 F150. MSD suggested that I upgrade to a hotter spark plug. My question is how do I figure out what a hotter plug is? Any help would be greatly appreciated. Thanks in advance.
Bill
Old Feb 22, 2002 | 01:02 AM
madman666's Avatar
madman666
Hotter spark plugs?
I don’t think you'll need to get hotter plugs, just get some new ones and side gap them.
I’m not to sure what plug to put in if you want to run the hotter plugs, someone else may know.
Old Feb 25, 2002 | 01:59 PM
MustangGT221's Avatar
MustangGT221
Hotter spark plugs?
Old Feb 25, 2002 | 08:51 PM
KDAWGMXRACER's Avatar
KDAWGMXRACER
Hotter spark plugs?
just ask the guy at the auto parts store and he will tell you.//
i have heard that plugs with longer insulators (the white part of the plug) are the cooler plugs and the shorter the insulator the hotter the plug...
Old Feb 25, 2002 | 08:53 PM
Pastmaster's Avatar
Pastmaster
Hotter spark plugs?
I think they mean hotter spark. I run the normal Motorcraft plugs with my MSD setup on my 93 F-150, and have no problems at all. I do put new plugs in every year, and they always come out clean.
'93 F-150 loaded and modified!
Check my Gallery
Old Feb 26, 2002 | 10:25 AM
michaelskerrett's Avatar
michaelskerrett
No, it really refers to the temperature of the spark plug not the spark. The amount of voltage (and current) it takes to jump the gap yields just about the same spark temperature regardless of plug temperature. Hotter plugs have less metal contact with the engine block and hence do not dissipate as much of the heat that is produced due to normal operation. The reverse is true for cooler plugs. With newer engines and unleaded gas the need for hotter plugs is reduced. If you are in the high-performance arena and are running higher than normal compression ratios the change may be necessary. The best thing to do is replace the plugs with the OEM recommended part. You can find that part number under the hood, in any of the repair manuals or in the catalogs (or on-line) at auto parts places.
Old Feb 26, 2002 | 10:29 AM
michaelskerrett
One more thing, I think MSD recommends re-gapping your plugs. Check the installation instructions, or ask someone in the electronics board, for the specs for your truck and unit.
Old Feb 27, 2002 | 01:08 PM
groundrat's Avatar
groundrat
Hotter spark plugs?
Thanks for the info. I will check in to the re-gapping. Truck runs real good now, so I may not even bother. Thanks for all the help guys.
Bill
