Engine misfire
Old Sep 7, 2015 | 10:07 AM
daddylee100's Avatar
daddylee100
Engine misfire
Drove my truck 92 in sig to the beach 60 miles ran fine. Drive it home last night and it ran fine again until I got off the freeway. As I came to the signal it had a pretty bad misfire/rough idle. Once you get above the 1200-1500 rpm range you cannot feel it at all and it runs fine. New plugs, wires, cap and rotor 10,000 miles ago, new iac and fuel filter even less then that. No codes relating to this at all.
Old Sep 7, 2015 | 04:00 PM
daddylee100
Engine misfire
Bump. Truck runs great above 1000/1200 rpms. Checked base timing with spout unplugged and it's at 10*
Old Sep 7, 2015 | 07:52 PM
TobaccoBarn460's Avatar
TobaccoBarn460
I guess if it was me, based on what you've said, I might think back to where I got my last load of fuel.
Since I just got off the highway, and the EGR is open for an extended period, I might wonder if it had closed right after getting off the highway.
Ignition, spark, or air would be where you'll look for starters.
Old Sep 7, 2015 | 07:53 PM
timbersteel's Avatar
timbersteel
Pop the hood in the dark, no outside light to interfere and look for arcing
Old Sep 7, 2015 | 08:08 PM
daddylee100
Engine misfire
Both tanks filled at chevon before the trip. 60 miles each way so it was about 120 ish before any problems
MotherWolf
Nov 26, 2014 05:08 PM
grizzly812
68
Jul 29, 2010 01:08 AM
uhoh826
Mar 9, 2009 11:13 PM
baylesr
30
Aug 10, 2008 02:35 PM
cadman
Jan 26, 2002 06:59 PM
