Brake issues
Old Sep 5, 2015 | 09:36 PM
ultraranger's Avatar
ultraranger
Originally Posted by brian1080
I can see how having the rod too far out would hurt,, it could keep the rear seals from seating and always allowing air to bleed into the chamber. I'll check it and see if that solves the problem. thanks for the link ultra.
You are welcome.
A booster rod adjusted too far out will preload the MC pistons. This will keep a small amount of pressure on the brakes, even when you aren't pressing down on the brake pedal. It can also make it very difficult to completely bleed the brake system out if the MC pistons can't fully retract.
A booster rod that is adjusted too short will cause the brake pedal to have a long travel before you get any significant pressure acting on the brakes.
andrewscofield
Sep 11, 2019 10:55 AM
Captbs32
1978 - 1996 Big Bronco
Aug 1, 2011 12:06 AM
LTCPipkin
Aerostar
Oct 28, 2007 08:56 PM
Katmandu
Mar 11, 2005 09:41 AM
JFR3
Jul 15, 2003 03:54 PM
