Soft Brakes?
Old Jul 15, 2003 | 08:59 AM
JFR3's Avatar
JFR3
Soft Brakes?
I recently had a new power brake booster and master cylinder installed, new rear wheel cylinders, brake lines, complete new rear brake setup and drums, front pads and calipers. The problem is that the brakes are so darn touchy, i.e., pedal very soft and it seems that the pedal is not coming all the way back up after you stop. I'm wondering if there is a vacuum problem. Can I put a vacuum gauge on the hose coming off the manifold that would go to the brake booster to see if I've got enough pull? What should I expect? If there isn't enough, how do I get more? Could there be something haywire with the proportioning valve? A brake expert, I'm not.
The engine is running good, but I can't seem to figure this out. Any comments greatly appreciated. Pictures of the beast soon.
Old Jul 15, 2003 | 09:15 AM
Huntsman's Avatar
Huntsman
Soft Brakes?
Soft pedals usually indicate the lines still have some air in them. If it were me, I would try bleeding the brakes, beginning with the rt. rear and working back toward the master cylinder. (rt rear- lt. rear-rt. frt.- left frt.)
Old Jul 15, 2003 | 09:21 AM
beartracks's Avatar
beartracks
Soft Brakes?
If you paid to have this done I would definitely take it back and declare it a safety hazard and demand they make it right. You probably paid a few bucks for the job.
Soft pedal generally will be air but would not relate to grabbing/touchy. They may not have the length set right on the push rod on the booster.
There should be a large hose from the manifold to the booster with a plastic one way valve where it connects. You can pull it off with the engine running (leave the valve in) and hear vacuum. you should also be able to press the brake pedal once or twice before the vacuum in the booster is used up.
Old Jul 15, 2003 | 03:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Soft Brakes?
Take it back to the shop. There may also be a worn bushing or spring in the brake pedal mechanism.
andrewscofield
Sep 11, 2019 10:55 AM
78 Ford F150 460
13
May 18, 2013 01:45 PM
burnout400m
35
Mar 22, 2012 08:46 PM
fwerring
Aug 31, 2010 03:52 PM
dragonman
1978 - 1996 Big Bronco
Mar 12, 2010 07:24 AM
