maintenance
Old Aug 2, 2003 | 07:48 PM
fordeverpower's Avatar
fordeverpower
maintenance
Can anlone tell me were to add the blinker fluid. Also has anyone replaced there muffler belts?
Old Aug 2, 2003 | 08:25 PM
TheWiz427's Avatar
TheWiz427
maintenance
Old Aug 2, 2003 | 08:41 PM
briggs1100's Avatar
briggs1100
maintenance
You add the Blinker fluid right next to the Head light fluid on the top of the steering column. And there is only one belt on the muffler.
Old Aug 2, 2003 | 09:03 PM
Matts72's Avatar
Matts72
maintenance
Thats unless its a Pre-96 then there are two. If its a red car then you have to fill the reservoir on the blinkerfluid before you fill the main tank.
Old Aug 2, 2003 | 09:27 PM
dtpatt2's Avatar
dtpatt2
maintenance
hmmm. Matt is the main reservoir right next to the turbo charger fluid?
Old Aug 2, 2003 | 09:51 PM
theologian's Avatar
theologian
maintenance
I had a blinker fluid leak once - it took the paint of the inside of the fender. It had rusted right through before I noticed it.
Theo, nearly as crazy as the rest of you...
Old Aug 2, 2003 | 10:05 PM
Matts72's Avatar
Matts72
maintenance
The reservoir is the right rear tire. Assuming your vehicle came with one.
Old Aug 2, 2003 | 10:20 PM
fordeverpower
maintenance
Hey I am serious about the blinker fluid. My turn signals are not working. My muffler isn't working right either maybe I should take it to a shop to be looked at.
Old Aug 2, 2003 | 10:25 PM
Matts72's Avatar
Matts72
maintenance
Maybe, shops are real good at fixing things, and taking the weight out of your wallet.
Old Aug 2, 2003 | 10:39 PM
Vampiro's Avatar
Vampiro
maintenance
oooooooooooooooookay!
buddy. let me be the first to say blinkers dont have fluid. they have flashers. check that first. mufflers dont have belts. a muffler will work as long as it aint rotten.
if you walk into a shop like you did hear and say your muffler belt is broken your gonna pay a arm, leg and first born to fix your car
Old Aug 2, 2003 | 10:46 PM
Matts72's Avatar
Matts72
maintenance
I thought you were joking. You better be.
Old Aug 2, 2003 | 10:59 PM
Mil1ion's Avatar
Mil1ion
maintenance
Do your legs feel longer ?
Old Aug 2, 2003 | 11:07 PM
fordeverpower
maintenance
I thought we needed some comedy around here thats all folks!
Old Aug 2, 2003 | 11:20 PM
BigMattXXL's Avatar
BigMattXXL
maintenance
As long as your hose belt and Flux Capacitor are in good shape, I'd say you're doing fine.
If not, the hose belt is easy to replace - you only need an adjustable metric wrench.
XXL
Old Aug 2, 2003 | 11:23 PM
Matts72's Avatar
Matts72
maintenance
XXL
Thats a good one Matt. I will have to remeber that.
